I think I'm just going to settle with changing my OSC value. I managed to complete the code and generate my 350Hz and being able to turn it on and off. Thanks for everyones help. My code is listed below:
'device PIC12F683
OSCCON = %00100101 '250kHZ system clock
CCP1CON = %00001100 'Select PWM Mode
T2CON = %00000100 'Timer2 = ON + 1:1 prescale
PR2 = 177 'Max Value = 255 Set PWM Period for 350Hz
CCPR1L = 150 'Set PWM Duty-Cycle to 85% (177*0.85 = 150)
TRISIO.2 = 0 'GPIO.2 (GPIO.2 = Output)
TRISIO.1 = 0
PIN_VOLTAGE VAR BYTE
INPUT GPIO.1 'Button input
OUTPUT GPIO.4 'Red LED
OUTPUT GPIO.5 'Green LED
BEGIN:
ADCIN 1, PIN_VOLTAGE 'ADCIN - Button Voltage Level
IF PIN_VOLTAGE >= 163 THEN 'Voltage greater then 3.2V
GOTO TURN_OFF_PULSE
IF PIN_VOLTAGE <= 160 THEN 'Voltage less then 3.2V
GOTO TURN_ON_PULSE
TURN_ON_PULSE:
TRISIO.2 = 0 'Turn ouput pulse on - make timer an output
low GPIO.4 'Turn Red LED off
HIGH GPIO.5 'Turn Green LED on
PAUSE 32 'Wait 0.5sec
LOW GPIO.5 'Turn Green LED off
GOTO BEGIN
TURN_OFF_PULSE:
TRISIO.2 = 1 'Turn output pulse off - make timer an input
HIGH GPIO.4 'Turn on Red LED
goto begin
