Maths help for the terminally dim please
Results 1 to 13 of 13
    Thumbs up
    Thanks for the formula as well. Now i know how to do it
    Default Re: Maths help for the terminally dim please
    Another maths question.
    I have an adc connected to a HV supply via a non linear isolation circuit.
    It produces the below 10bit ADC readings at the given input voltage.
    That works fine but i want to create a formula from these data points to allow the adc to produce the actual voltage.
    I don't want to use a lookup table if possible.
    Accuracy to 1V is acceptable. There should be enough adc resolution to do that with the right formula.
    225v = 356
    200v = 380
    175v = 412
    150v = 450
    125v = 495
    100v = 561
    75v = 644
    50v = 753
    25v = 903
    10v = 1000
    5v = 1020
    0v = 1023
    How to convert that data into some sort of forumla to produce the voltage from a given adc reading.
    It's not linear.
    3rd degree Polynomial Fit: y=a+bx+cx^2+dx^3...
    Coefficient Data:
    a = 7.84284692277E+002
    b = -2.42579262304E+000
    c = 2.77307340820E-003
    d = -1.12332698305E-006
    or
    Heat Capacity Model: y=a+bx+c/x^2
    Coefficient Data:
    a = 8.77447057194E+001
    b = -1.01937213402E-001
    c = 2.18878991436E+007
    or use a retrieve table plus 2nd order approx.
    did you notice 1v is ... 0.5% ???
    surely not !!!
