Displaying Videos and Images on 4Dsystems uOLED Serially
Results 1 to 40 of 68
    Oct 2010
    Default Re: Displaying Videos and Images on 4Dsystems uOLED Serially
    hi Dave again,
    now i get the following errors.
    I dont want to disturb you more.
    I'm really sad to not understand what are these errors and why it does not work.
    regards
    '*  Name    : TAG NUMBER.BAS                                    *
    '*  Author  : LEONARDO BILALIS                                  *
    '*  Notice  : Copyright (c) 2011 [LEONARDOS BILALIS]            *
    '*  Date    : 11/6/2011                                         *
    '*  Notes   : this program allows you to see the                *
    '*          : Number of the RFID tag                            *
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_ALL & _DATA_CP_ON
    Include "MODEDEFS.BAS"
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    CMCON = 7
    LED   VAR  PORTB.3
    T1CON = $31                ; Prescaler = 8, TMR1ON
    DEFINE OSC 8	'Set oscillator in MHz
    DEFINE LCD_DREG PORTB  'define port to LCD
    DEFINE LCD_DBIT 4      'RB4 RB5 RB6 RB7 to D4 D5 D6 D7 display
    DEFINE LCD_RSREG PORTA 'RS on porta
    DEFINE LCD_RSBIT 0     'RS on porta.0
    DEFINE LCD_EREG PORTA  'Enable on porta
    DEFINE LCD_EBIT 1      'Enable  porta.1
    DEFINE LCD_BITS 4      '
    DEFINE LCD_LINES 2     'lines 2
    PAUSE 200             ' Stop 200ms
    LCDOUT $FE,1           ' power lcd
    Lcdout $FE,1,4
    lcdout $FE, 1," Copyright 2011"
    lcdout $FE, $C0,"Leonardo Bilalis"
    ' -----[ Variables ]-------------------------------------------------------
    buf	    VAR	byte [10]' RFID bytes buffer
    tagNum	VAR	Byte	 ' from EEPROM table
    idx	    VAR	Byte	 ' tag byte index
    char	VAR	Byte	 ' character from table
    lcdout $FE,1," Please use your"
    lcdout $FE, $C0,"Personal RFIDTAG"
    SERIN2 portb.1, 84, [WAIT($02),Str buf\10]
    LCDout $fe,1, "TAG ID:"
    lcdout $fe,$C0, "NO: ", str buf\10
    pause 5000
    ToggleLED1:
    TOGGLE led
    @ INT_RETURN
    No problem.
    Try changing the config line to
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    and make sure the *.inc file is commented.
    Then add
    wsave VAR BYTE $70 SYSTEM
    in your VAR section
    Oct 2010
    i have fixed a lot of problems by adding your suggestions.
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    CMCON = 7
    LED   VAR  PORTB.3
    DEFINE OSC 4	'Set oscillator in MHz
    DEFINE LCD_BITS 4      '
    Lcdout $FE,1,4
    pause 5000
    ToggleLED1:
    TOGGLE led
    @ INT_RETURN
    now i only get the following
    error [118] overwriting previous address contents [2007]
    Gettin there....
    Take a look at this
    http://www.picbasic.co.uk/forum/show...=6775#post6775
    When the configs are set in code space the *.inc file needs the config lines commented.
    Oct 2010
    i feel that if i make any change in the inc file under the original device 16f628a i will make a mess.
    when i open the inc file of the 16f628a i cannot save it because access is denied. Is that has to do with my permissions as admin?
    Oct 2010
    thank you very much for your time and for your help.
    i fixed it.!!!!!
    Oct 2010
    after a long time i would like to add some features on the code i'm currently trying to fix.
    I got an 3.2" ulcd PT from 4DSystems.
    I would like to create a program that i could control an iconic 4x3 keyboard serially from the display.
    For example i would like to add 4x3 buttons and ones i touch them, to get a feedback on the display.
    I have tried to create a very simple program as the start, by creating: Draw Text Button - 62hex, no luck!!!
    the command as from the Manual has the following configuration :
    cmd, state, x(msb:lsb), y(msb:lsb), buttonColour(msb:lsb), font, stringColour(msb:lsb),
    width, height, “string”, terminator
    the problem is that i dont know what to use at x and y as the width and height!
    After that i need to create a touch commands i guess! I have a lot of work.
    It is very confusing and there is no example at all a their site or manuals.
    I will be able to check the code again on Friday because i'm at a business trip (again )
