Displaying Videos and Images on 4Dsystems uOLED Serially
Results 1 to 40 of 68
    Default Re: Displaying Videos and Images on 4Dsystems uOLED Serially
    Maybe there is a sleep command?
    Power off means that it may not communicate again, as it is ... off!
    Oct 2010
    hi Ioannis,
    there is a sleep command but i think it does not turn the display backlight off.
    I will try it and keep you updated.
    Oct 2010
    what i have noticed is:
    when you use the sleep mode ($5A) it turns off only display like a clear lcd command.
    when you use the display off command $59 it completes shut down the display.
    i managed to turn on the diplsay again. I'm happy but still the program has a lot of bugs, because i dont know if this procedure is safe for the display.
    what i mean:
    first i initialize the display by the command $55 which is also the autobound.
    this has to be paused for approximatelly 200ms or more. I have put it on 1000 ms.
    Then after all i use commands to display pictures.
    The first picture is the logo.
    In order to shut down the display, i use the $59,$00 inside the gotosub logo, and then i turn off the display.
    Then when i use a tag to RFID reader, inside the tag_found command i use the command $59,01 to turn on the display.
    i will upload a video so you understand what i do. Do not panic for my bugs.....i know there are a lot but have in mind that i'm not a programmer and i dont know how to use the interrupt command at all.
    thanks for understanding.
    Oct 2010
    here is the video of what the $59,$00 command does
    Oct 2010
    based on the above video i would like a little bit of help?
    as you see the first picture (the blue "star", actually it is a symbol,but anyway), it dissapear from the screen and then the screen goes off.
    I would like to do something but i dont really know how to use inrerrupt.
    I want to display this symbol every 5 seconds, and when the tag pass from the reader, to display the picture that corresponds to the tag.
    I think this can be done using interrupt but i have never used it and i have read some programs, but cannot understant.
    do you have any simple example using an led flashing and a button that interrupts the process?
    thanks for any help.
    Interrupts get fast and easy using Darrel's Instant Interrupts, no setting up registers, no latency of PBP interrupts. Which interrupt do you want to use? Look at the data sheet to see what is available for your chip and check out Darrel's webpage:
    http://darreltaylor.com/DT_INTS-14/intro.html
    Oct 2010
    thanks for your help,
    i will check it out.
    Oct 2010
    i've been trying to use the interrupt commands but i get a lot of errors. I used both files
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
    First error i get is that micro assembler does not support 16F628a, and it is asking to use the MPASM for compiling.
    then if i use the MPASM i get again a lot of error like the attached pic.
    i dont understand why it says that cannot filnd the pic16f628a.
    here is also my code
    '*  Name    : TAG NUMBER.BAS                                    *
    '*  Author  : LEONARDO BILALIS                                  *
    '*  Notice  : Copyright (c) 2011 [LEONARDOS BILALIS]            *
    '*  Date    : 11/6/2011                                          *
    '*  Notes   : this program allows you to see the                *
    '*          : Number of the RFID tag                            *
    @ DEVICE PIC16F628a
    Include "MODEDEFS.BAS"
    CMCON = 7
    LED   VAR  PORTB.3
    T1CON = $31                ; Prescaler = 8, TMR1ON
    DEFINE OSC 8	'Set oscillator in MHz
    DEFINE LCD_DREG PORTB  'define port to LCD
    DEFINE LCD_DBIT 4      'RB4 RB5 RB6 RB7 to D4 D5 D6 D7 display
    DEFINE LCD_RSREG PORTA 'RS on porta
    DEFINE LCD_RSBIT 0     'RS on porta.0
    DEFINE LCD_EREG PORTA  'Enable on porta
    DEFINE LCD_EBIT 1      'Enable  porta.1
    DEFINE LCD_BITS 4      '
    DEFINE LCD_LINES 2     'lines 2
    PAUSE 200             ' Stop 200ms
    LCDOUT $FE,1           ' power lcd
    Lcdout $FE,1,4
    lcdout $FE, 1," Copyright 2011"
    lcdout $FE, $C0,"Leonardo Bilalis"
    low led
    high led
    low led
    high led
    ' -----[ Variables ]-------------------------------------------------------
    buf	    VAR	byte [10]' RFID bytes buffer
    tagNum	VAR	Byte	 ' from EEPROM table
    idx	    VAR	Byte	 ' tag byte index
    char	VAR	Byte	 ' character from table
    lcdout $FE,1," Please use your"
    lcdout $FE, $C0,"Personal RFIDTAG"
    SERIN2 portb.1, 84, [WAIT($02),Str buf\10]
    LCDout $fe,1, "TAG ID:"
    lcdout $fe,$C0, "NO: ", str buf\10
    pause 5000
    ToggleLED1:
    TOGGLE LED
    @ INT_RETURN
    if you have any suggestion please let me know.
    thanks a lot for your help.
