Is RX needed? That is why I pointed you to the reference manual for both displays.
You can get by without using RX but I would highly recommend that you use it. Take a look at post #12 - you will see that the display returns an ACK if the command is successful, NAK if unsuccessful. This can make your application run more effectively.
