that is perfect.
I will place an order for a small ulcd first 1.44" and then i will try a bigger one.
thanks a lot.
that is perfect.
thanks a lot.
The main difference between the large and small displays, besides size, are
1. No touch screen.
2. Less memory.
3. Subset of commands.
I have used both, and they work well. The reference manual for the small display is here http://www.4dsystems.com.au/download...S-SIS-rev4.pdf
i see i ok for programming but when i get it i might need some help.
thanks for your help.
i will place the order for the small 1,44 tomorrow
Hello,
i see that the pins for controlling serialy the 1,5' Oled Display http://www.sparkfun.com/products/8537 is the VCC, TX, RX, GND, RESET
So do i need to use a microcontroller with TX, RX pins? The RX is needed?
On the codes that Mr. RFEFX posted, i think he used only the TX on the controller.
on the next line
he used the serin for RFID only, the logo command in there goes to serout lineCode:serin2 rfidin,396,1000,Logo,[WAIT(10),str BUF\10]
please could you tell me if i'm wrong. If yes then what do i need the RX for?Code:serout2 lcd,84,[$40, $49, $00, $30, $7F, $1F, $10, $01, $8A, $EE]
thanks.
Is RX needed? That is why I pointed you to the reference manual for both displays.
You can get by without using RX but I would highly recommend that you use it. Take a look at post #12 - you will see that the display returns an ACK if the command is successful, NAK if unsuccessful. This can make your application run more effectively.
rmteo, thanks once more for your help.
That's why i ask you, now i see the response from the RX.
I have some SD cards here, and i would like to format them in windows 7 64bit.
I read some forum and manuals but i didnt see the format of erasing the microsd.
I did the following configuration.
Capacity : 1,83Gb
file system: FAT (default)
Alocation unit size: default
Format option: -
the only thing i found is the following migh also be interesting for you.
http://www.picaxeforum.co.uk/showthread.php?t=13971
Those parameters are correct for a 2GB card under Win7. Note that both displays use micro-SD cards - not SD.
Make sure you download the Graphics-Composer Software Tool: This is a free software tool for Windows. This software tool is an aid to composing a slide show of images/animations/movie-clips (multi-media objects) which can then be downloaded into the memory card that is supported by the GOLDELOX-GFX2. The multimedia objects can then be called within the user application 4DGL program.
