Simcom 900d-ftp
Results 1 to 2 of 2
Thread: Simcom 900d-ftp
    Sep 2009
    Default Simcom 900d-ftp
    I have a Simcom 900D with firmware 1137B06SIM900M64_ST, that supports FTP.
    Here is HTTP/FTP AT Command list
    an_sim900_ip_application note_v1.00_draft.pdf
    But no matter how I tried to send a file, always get a net error. The same error also with http.
    I don't understand how to use the AT + SAPBR
    I managed to send file like this:
    AT+CGEREP=1
    OK
    at+cipmux=1
    OK
    AT+CREG=1
    OK
    AT+CGREG=1
    OK
    AT+CGATT=1
    OK
    AT+COPS?
    +COPS: 0,0,"YUG 03"
    OK
    AT+CSTT="gprsinternet","mts","064"
    OK
    AT+CIICR
    OK
    AT+CIFSR
    172.30.7.93
    AT+CIPSTART=0,"TCP","ftp.****.com",21
    OK
    0, CONNECT OK
    +RECEIVE,0,322:
    220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
    220-You are user number 2 of 1000 allowed.
    220-Local time is now 08:13. Server port: 21.
    220-This is a private system - No anonymous login
    220-IPv6 connections are also welcome on this server.
    220 You will be disconnected after 15 minutes of inactivity.
    at+cipsend=0
    > User ****@****.com
    0, SEND OK
    +RECEIVE,0,58:
    331 User ****@****.com OK. Password required
    at+cipsend=0
    > Pass*****
    0, SEND OK
    +RECEIVE,0,105:
    230-User ***@***.com has group access to: **
    230 OK. Current restricted directory is /
    at+cipsend=0
    > pasv
    0, SEND OK
    +RECEIVE,0,50:
    227 Entering Passive Mode (**,147,240,**,32,54)
    AT+CIPSTART=1,"TCP","**.147.240.**",8246
    OK
    1, CONNECT OK
    at+cipsend=0
    > stor simcom900d muxip.txt
    0, SEND OK
    +RECEIVE,0,30:
    150 Accepted data connection
    at+cipsend=1
    >test text
    1, SEND OK
    at+cipsend=0
    > bye
    0, SEND OK
    +RECEIVE,0,21:
    500 Unknown command
    AT+CIPCLOSE=1
    +RECEIVE,0,9:
    226-File successfully transferred
    226 131.780 seconds (measured here), 0.46 bytes per second
    1, CLOSE OK
    AT+CIPCLOSE=0
    0, CLOSE OK
    AT+CPOWD=1
    +PDP: DEACT
    NORMAL POWER DOWN
    But not using FTP commands.
    Does anyone know how to send the file to the ftp using ftp command, or has some advice, suggestion?
    Sep 2009
    It' shpuld be: But not using modem FTP commands.
