confusion with the CD74HC165 8 bit register
Results 1 to 30 of 30
    Also the PL (parallel load) signal needs to be High in order to clock data out of the serial data pin, but also needs to go low in order to sample the data on the parallel pins. Simplest thing to do is to invert the CE signal and use that to control the PL signal. That is how I turned the HC165 into a simple SPI-like interface (Clock, Data out, and Chip Enable).
    Tim Barr
    Sep 2006
    Default almost there
    Ok, I understand pretty much how the chip works, it was the bridge between how Picbasic language treat the shiftin code that was troubling me.
    Ok I have this code on a Pic16F887, I am only getting '00' as my output, I tried switcing ports ( CP and PL just to see, but no luck). My parallel input have random 0 and 5v for try out.
    '@ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    OSCCON = %01110000 '8 Mhz
    DEFINE OSC 8
    ANSELH = 0
    '// LCD configuration //
    DEFINE LCD_DREG PORTB 	' Set LCD Data port
    DEFINE LCD_DBIT 4 		' Set starting Data bit (0 or 4) if 4-bit bus  RB.4, RB.5, RB.6, RB.7
    DEFINE LCD_RSREG PORTB 	' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 		' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB	' Set LCD Enable port
    DEFINE LCD_EBIT 0 		' Set LCD Enable bit
    DEFINE LCD_BITS 4 		' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 		' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    TRISE = %11111100 	' Set PORTE to all input
    Clock   var PORTE.0   'CP
    Load    var PORTE.1   'PL
    Data_1  var PORTE.2  'Q7  out
    input1 var byte
    Mainloop:
    pulsout Load,1
    shiftin Data_1,Clock,0,[input1 \8]
    	lcdout $FE,1, "Shift in"
    	lcdout $FE,$C0, dec2 input1
    	pause 300
    GOTO Mainloop
    It has been a couple of versions of PBP since I have used a shiftin register, but I remember
    something about the MODE numbers not working. I know, it should not make a difference.
    Just for giggles try.
    include "modedefs.bas"
    shiftin Data_1,Clock,MSBPre,.....
    Like Tim said, the PL needs to idle high in order to shift the data out. To load the 8 bits into the register you pulse it low - you're currently doing it the other way around. Set the Load pin high initially, the Pulsout will then produce a pulse with the correct polarity.
    Sep 2006
    Tim,
    How do you invert the CE signal with the PL pin. Do you direct connect both pins with an inverter? I guess my hardwireing is wrong...
    K
    Sep 2006
    putting the PL low .. something like that ??
    input1 var byte
    Mainloop:
    low Load
    pulsout Load,10
    	pause 300
    GOTO Mainloop
    No, the other way around...it must idle HIGH. It should always be HIGH except for that moment you want to "capture" the 8 databits. Put a HIGH Load before your mainloop, the Pulsout command will then pulse it low for you.
    Quote Originally Posted by lerameur View Post
    I would do this (and make sure the CE pin is pulled low always) :
    input1 var byte
    low Load
    Mainloop:
      high Load
      low Load
      pause 300
    GOTO Mainloop
    Tim Barr
    Tim,
    K
    That is how I did it. Mode 0 looks like the proper one to select.
    But, because of the way the PL signal works (CLK disabled if PL is low), you could wire the CE low and just use the PL signal to control operation. Just set PL high before you execute the SHIFTIN command and set it low after the command is finished.
    Tim Barr
