In the left column it's possible to select things like labels, variables, includes etc, and an option for none. Would it be possible to have an option for all, in the same way MCS does.
Ive also noticed that when a file is opened in FL it changes the text of the commands. For example
Note the lower case "if" in the last two lines. I then use the option to open in MCS and looked at the same set of linesIF Temperatures(pid_Channel) > alarmhigh(pid_Channel) and Alarm = 1 then AlarmPin = 1
IF Temperatures(pid_Channel) > alarmhigh(pid_Channel) and Alarm = 0 then AlarmPin = 0
IF Temperatures(pid_Channel) <= alarmhigh(pid_Channel) then AlarmPin = 0
IF Temperatures(pid_Channel) <= alarmlow(pid_Channel) then AlarmPin = 0
if Temperatures(pid_Channel) < alarmlow(pid_Channel) and Alarm = 1 then AlarmPin = 1
if Temperatures(pid_Channel) < alarmlow(pid_Channel) and Alarm = 0 then AlarmPin = 0
Formatting was correct....IF Temperatures(pid_Channel) > alarmhigh(pid_Channel) and Alarm = 1 then AlarmPin = 1
IF Temperatures(pid_Channel) < alarmlow(pid_Channel) and Alarm = 1 then AlarmPin = 1
IF Temperatures(pid_Channel) < alarmlow(pid_Channel) and Alarm = 0 then AlarmPin = 0
