FineLineIDE
Results 1 to 40 of 188
Thread: FineLineIDE
Threaded View
  1. #17
    Norm , I just downloaded your latest version and I think it needs a bit more work. I use TAB's for my indenting and when edited with MCSP it looks as it should. When the same program is loaded into your latest version, it seems to get confused about the tab spacing and also seems to get confused about where to put the connecting lines to the left side of the screen. There are places where multiple connections are all covered up by the same line... If you can give me your email address I will send you the some screen shots...
    dave Purola,
    FL requires an indent to allow room to draw to left of text.
    See how finelines draw to left of "SensorError:" label in post #1.
    Try a select all and indent one step.
    I will look into the tabs replacement width issue.
    Norm
