Hi All
Has anyone got V3.3 running on windows 10?. I can set PBP3 path etc in options but it forgets it after selection.
Cheers Pete
Hi All
Cheers Pete
Hi Norm
Yes, I tried both adding it manually and also ticking the box when its automatically found. It does the same thing with the compiler too. I did add it manually to the ini file and that worked. I`ve not done that yet for the compiler as I'd like to see why its happening.
Cheers Pete
Hi Norm
Tried it root C: Program files, desktop even via dropbox. I can find and select for example the compiler, click OK then if I try to select a PIC from the dropdown I get "Find PBPx.EXE in Options". If I go back in the selection has gone. I`m wondering if its Windows 10 specific. Cheers Pete
I just now downloaded FL 3.3 onto a Windows 10 machine and it compiles OK and closes and reopens and compiles again.
On compile FL does prompt to switch from PBP3 to prePBP3 when needed and if so you will need to find the other compiler in options but just once for each.
Not likely but I wonder if administrative privileges are required for an ini save?
Norm
