FineLineIDE
Results 1 to 40 of 188
Thread: FineLineIDE
    Default Re: FineLineIDE
    Quote Originally Posted by Gusse View Post
    Hi Norm,
    Thanks for the new version of FineLineIDE. I was trying it when I noticed something strange. Only part of code was visible in FineLineIDE and after debugging reason was Scandinavian letter in comment line. There is something weird happening if code have one or more of these letters: Ä,Ö,Å or ä,ö,å.
    Also, I had difficulties to set PicBasicPro Compiler in Options menu. I fix this, by manually editing FineLineIDE.ini file. After manual modification to ini-file, file compiled OK.
    -Gusse-
    Gusse I PM you a beta 3.01 to test retaining non English text.
    Norm
    Hi Norm,
    I think I found the problem. I am running windows in a VirtualBox but the files are stored on the host OS. I tried putting the file in the windows environment and the error went away.
    If it is any help, the machine I tried this on has openSUSE as the host and Windows7 as the guest.
    Hi Norm, first, a big thank you for the wonderful tool.
    I use it as my default IDE, but go over to the 'other' IDE every time I need to use the ICD.
    I believe you had released a plugin for Proton to be able to compile for ICD; is there a chance a similar feature would be available for PBP?
    Thanks again.
    Thanks again.
    Glad to see your making good use of FL!
    It wasn't me who made the ICD plugin for Proton.
    There are no plans to add one to FL as time doesn't permit.
    FL does include a "Compile and MPLAB sim" button to help load for sim in MPLAB however.
    Else continue to use the "Open in Orig IDE" to sim in Microcode Studio as needed.
    Norm
    Oh okay, thanks for the prompt response.
    FineLineIDE v3.2 is now available.
    FL v3.1 changes FL's method of opening files as some users files didn't fully open.
    FL v3.2 replaces non English text with spaces on open, paste and save.
    The non English text was causing FL to freeze as FL does not support UNICODE.
    Norm
    FineLineIDE v3.3 is now available.
    v3.3 has a low profile toolbar with selectable large or small icons and view or hide individual icons.
    Should benefit laptops or smaller screens.
    Norm
