Having trouble with SERIN command and MAX6675
Results 1 to 40 of 40
Threaded View
  1. #23
    May 2008
    Italy
    MAX6675 need more than 200 millisecs for the temperature convertion. You are polling too fast so you don't get any response. Place a delay of 250 msecs to allow convertion.
    edit:My note was reffered to code seen in post#5. I just see that you added delay 500 in your code in post #7, so my answer is obsolete.
    My new suggestion are :
    add INCLUDE "modedefs.bas" on top of your code
    and modify your SHIFTIN command adding:
    shiftin MXSO, MXSCLK, MSBPRE, [MXTemp\16] 'read the data to MXTemp
    and see if it works.
    Al.
