Having trouble with SERIN command and MAX6675
Results 1 to 40 of 40
    Default Re: Having trouble with SERIN command and MAX6675
    And I will add... Take extra care with your cold junctions. The 6675 does a good job compensating if the junction is close and in the same environment as it is. As do not have the cold junction on the outside of an enclosure and the 6675 on the inside. And noise that can be picked up from breadboard connections can be trouble.
    SWITZERLAND (french speaking)
    ...As do not have the cold junction on the outside of an enclosure and the 6675 on the inside.
    How do you mean this?
    Roger
    The MAX6675 has cold junction compensation built in, but only works if the cold junction is close to the MAX6675.
    This article explains cold junction compensation in detail. https://www.maximintegrated.com/en/a...ex.mvp/id/4026
    Thumbs up Re: Having trouble with SERIN command and MAX6675
    Nice and very interresting.
    Thanks a lot
    Roger
