Having trouble with SERIN command and MAX6675
Results 1 to 40 of 40
    Default Re: it's working... but bit-shifting not clear to me :-(
    Unless you are trying to get the fractional part of the reading 10 bits is all you need.
    SWITZERLAND (french speaking)
    I don't get it, Dave...
    Roger
    Default Re: Having trouble with SERIN command and MAX6675
    why do I have to shift by "2" instead of what has been said above (shift by 3) or even shift by 1 since bit 14 is the second bit to start with?
    the data can be read in msb first by shiftin but it is then translated to a normal binary representation so bit 14 is read as bit 14.
    shifting by 2 is incorrect , as dave indicated
    Temp = RawTemp >> 5
    will get the high 10 bits of the 12bit reading ,resulting in the integer component of the reading
    or
    Temp = RawTemp >> 3
    int_part=temp/4
    fract_part=(temp//4)*25
    lcdout $FE, $C0,"Tmp ", #int_part,".",dec2 fract_part," C"
    This is confusing to me.
    My code gives me almost exactly what my home thermometer shows:
    This code
    Temp = RawTemp >> 3
    int_part=temp/4
    display this:
    Where is the truth?
    Roger
    for a start your temp var is a declared as byte , how can 12 bit reading fit in that ?
    I corrected my code just after I sent it - couldn't edit the post anymore, should have mentionned it, sorry
    Roger
    Anyway, I understand the calculation to get the temperature value BUT why do I have around 5°C diffrence between the thermocouple and my home thermometer?
    Must a thermocouple be kind of "adjusted" (correct the result in the code) or something like that?
    Roger
