Having trouble with SERIN command and MAX6675
Results 1 to 40 of 40
Threaded View
  1. #40
    Did you look at the data output pin on the MAX chip with your O-scope to see if it's changing the value sent?
    If you send 16 clocks, and the data line stays at ground, I would think there's a problem with the MAX IC. If you see transitions on the data line, there's something going on with the PIC side.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
