Having trouble with SERIN command and MAX6675
Results 1 to 40 of 40
Threaded View
  1. #3
    Dec 2010
    Wrong type of serial. This shows how to read it
    http://www.picbasic.co.uk/forum/show...1178#post71178
    And if you want degrees F add this bit
    TempF = ABS(TempC) */ 461
    TempF = TempF + 32
    I tried the code and when I compile I get a "Invalid RAM location specified". How can I fix this?
    Also, all I see on the LCD is a line of black boxes across the top row. Is this a timing problem?
    The same circuit setup works with my other lcd program so I know it's not a wiring error.
    I still need to change the ports...whoops
