Counter problem
Results 1 to 7 of 7
Thread: Counter problem
    Sep 2006
    Default Counter problem
    Hello,
    I am having difficulties troubleshooting this problem. I have a countdown timer and when it comes to 59:51 the next number it turns to is 59:44:
    the calculations is good , I did a simulation in excel and the formula does work, what the heck is the problem:
    I am using the DS 1337 and pic16F887
    OSCCON = %01110000 '8 Mhz
    DEFINE OSC 8
    ANSELH = 0
    '// Interrupt section //
    '// LCD configuration //
    DEFINE LCD_DREG PORTB 	' Set LCD Data port
    DEFINE LCD_DBIT 4 		' Set starting Data bit (0 or 4) if 4-bit bus  RB.4, RB.5, RB.6, RB.7
    DEFINE LCD_RSREG PORTB 	' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 		' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB	' Set LCD Enable port
    DEFINE LCD_EBIT 0 		' Set LCD Enable bit
    DEFINE LCD_BITS 4 		' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 		' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    '// PIN configuration //
    TRISB = %00000000 ' Set PORTB to all output
    TRISC = %11000000 ' Set PORTC to all output
    '// Variable Declaration and initialization //
    SDApin var PORTC.4                     ' RTC data
    SCLpin var PORTC.3                     ' RTC clock
    Total_time var word
    RTCSec var byte :RTCMin var byte :RTCHour var byte :RTCWDay var byte :RTCDay var byte :RTCMonth var byte :RTCYear var byte :RTCCtrl var byte
    lcdout $FE,1, "Bienvenue"
    lcdout $FE,$C0, "Welcome"
    '////////////////// PROGRAM /////////////////////////
    Mainloop:
    		if PORTC.6 =0 then
    		Gosub CountDown
    				lcdout $FE,1, "Out of Countdown"
    				lcdout $FE,$C0, " Press C.6 to Start "
    				Pause 150
    		Endif
    goto Mainloop
    CountDown:
    I2CWRITE SDApin,SCLpin,$D0,$00,[$00,$00,$00,$00,$00,$00,$00,$00] ' Write to DS1307 to start counter at ZERO
    Pause 20
    	while RTCHour != 1
    			I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
    			Pause 20
    				'Will get the time from timer chip and do a 60 min count down
    				'Also add interrupt if someone presses start to view the charge/discharge cycle
    				 Total_time = (RTCMin * 60) + RTCSec
    				 Total_time = 3600 - Total_time
    				lcdout $FE,1, "Time left"
    				lcdout $FE,$C0, " Diff: ", dec2 RTCHour, ":", dec2 Total_time/60 ,":", dec2 Total_time//60
    				Pause 150
    	Wend
    Sep 2006
    I also tried a clock program with the DS1337, works good, just that the seconds do not stop at 59, it continues to 80....or 89, thats was last night. How can the chip gives me this kinf of values ????
    K
    Sep 2005
    Campbell, CA
    The clock setting and ouput values are in BCD
    There are lots of DS1307 examples on the forum that explain the conversion.
    Charles Linquist
    Sep 2006
    I think it might the mod mode, I will try this tonight, basic basic basic:
    while RTCHour != 1
    			Pause 20
    				 Rest_seconds = 59 - RTCSec
    				 Rest_min = 59 - RTCMin
    				lcdout $FE,1, "Time: ", dec2 RTCHour, ":", dec2 RTCMin, ":", dec2 RTCSec
    				lcdout $FE,$C0, " Dif: ", dec2 RTCHour, ":", dec2 Rest_min ,":", dec2 Rest_seconds
    				Pause 150
    	Wend
    Sep 2006
    BCD... o crap, yes would explain why it went from 9 to 16 !!!, thanks. Missed that on the spec sheet.
    sec VAR BYTE ' seconds
    mins VAR BYTE ' minutes
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    date VAR BYTE ' date
    mon VAR BYTE ' month
    yr VAR BYTE ' year
     'DEC VARS
    SEC_O   VAR BYTE
    SEC_T   VAR BYTE
    MIN_O   VAR BYTE
    MIN_T   VAR BYTE
    HR_O    VAR BYTE
    HR_T    VAR BYTE
    MON_O   VAR BYTE
    MON_T   VAR BYTE
    DATE_O  VAR BYTE
    DATE_T  VAR BYTE
    YR_O    VAR BYTE
    YR_T    VAR BYTE
    READ_RTC:
    I2CREAD DS_SDA, DS_SCL, RTC, SecReg, [sec,mins,hr,day,date,mon,yr]
    SEC_T = sec & $70
    SEC_T = SEC_T>>4
    SEC_O = sec & $0F
    MIN_T = mins & $70
    MIN_T = MIN_T>>4
    MIN_O = MINs & $0F
    HR_T = hr & $70
    HR_T = HR_T>>4
    HR_O = hr & $0F
    MON_T = mon & $70
    MON_T = MON_T>>4
    MON_O = mon & $0F
    DATE_T = date & $70
    DATE_T = DATE_T>>4
    DATE_O = date & $0F
    YR_T = yr & $70
    YR_T = YR_T>>4
    YR_O = yr & $0F
