Hi, I am using a LCD for the first time so please forgive me for any mistakes and I have searched few threads and picked up few pieces to put together.
This is my code:
INCLUDE "modedefs.bas"
INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 5
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 1500
DEFINE LCD_DATAUS 44
sec var byte
minu var byte
hrs var byte
days var word
ADCON1=7
CMCON=7
OPTION_REG=128
TRISA=0 : PORTA=0
TRISB=0 : PORTB=0
TRISC=0 : PORTC=0
TRISD=0 : PORTD=0
TRISE=0 : PORTE=0
CCP1CON=0
@ ERRORLEVEL -306
wsave VAR BYTE $70 SYSTEM ' alternate save location for W
gosub reset
INT_Handler TMR1_INT, _counting, PBP, yes
T1CON=%00110000
TMR1L=%11011100
TMR1H=%00001011
@ INT_ENABLE TMR1_INT ; enable external (INT) interrupts
PAUSE 1000
Main3:
LCDOUT "HELLO" ;$FE,1,2, DEC days,"d-",DEC2 hrs,":",DEC2 Minu,":",DEC2 Sec
GOTO Main3
RESET:
sec=0 : minu=0 : hrs=0 : days=0
'---[INT - interrupt handler]---------------------------------------------------
counting:
sec=sec+1
if sec =120 then
sec=0
minu=minu+1
if minu=120 then
minu=0
hrs=hrs+1
if hrs=48 then
hrs=0
days=days+1
TMR1L=%11011100
TMR1H=%00001011
@ INT_RETURN
I am aware there is an elapsed timer file which can do this, but I am in a spirit of doing something myself. Once I am able to control the LCD properly, I will be trying to modify the main code to make my own 7 days timer.
I am using 16F877A and the connections page snapshot of the LCD is attached. I am using Matrix Multimedia's development board.
Thanks in advance.
