Serin Serout Help
Results 1 to 16 of 16
Threaded View
  1. #11
    Nov 2010
    Lightbulb Update
    I have been working on the code for a couple of days. I have made a small progression if i manually send a "1" to the SERIN it will assume a flash rate of 1. this is done by placing the datapin wire to ground. Hear is the current code i am working with. Any help would be great, Thanks!
    Recive:
    Clear
    define ocs 4
    INCLUDE "modedefs.bas"
    @_config_HS_osc &_WDT_OFF &_LVP_OFF &_CP_OFF &_BODEN_OFF
    ADCON1 = %00000111
    CMCON = %00000111
    TRISA = %11111111
    TRISD = %00000000
    X VAR BYTE
    SERIN2 PORTA.5\PORTA.1, 3313, [DEC X]
    LOOP1:
       HIGH PORTD.2
       PAUSE X
       LOW PORTD.2
       PAUSE X
    GOTO LOOP1
    Send:
    Clear
    define ocs 4
    ADCON1 = %00000111
    CMCON = %00000111
    TRISA = %00000000
    TRISD = %00000000
    PORTA = %00000000
    LED VAR PORTA.1
    X VAR BYTE
    X = 100
    LOOP1:
       SEROUT2 PORTA.5/PORTA.1, 3313, [100]
       PAUSE 5000
    GOTO LOOP1
    Thanks again!
    Last edited by ScaleRobotics; - 12th December 2010 at 22:02. Reason: added code tags
