Pic + RF Module or RFPIC
Results 1 to 13 of 13
    Question Pic + RF Module or RFPIC
    Good day
    I want to do RF communication..
    If I compare a Pic + separate RF Module with a RFPIC, it seems that the rfPic is cheaper and more reliable. Is this correct?
    If so, why do so few people use it?
    Not so sure they are cheaper.
    The receiver RFPIC still needs a "regular" PIC plus many other external parts.
    The transmitter is based on a 12F675. the 675 is a nice part but has limits.
    The RF modules like the ones Bruce sells are pretty much plug and play and can be used with any PIC.
    More reliable???
    Who knows???
    Dave, thank you very much for your reply!!
    What I want is a cheap and reliable way to transmit data.
    According to the microchip link (http://www.microchip.com/wwwproducts...cName=en010384) the rfPIC12F675K cost USD2.40
    I actually want the most cost effective way to Transmit RF data over about 15meters.
    I did play around with RF in the past and I struggled so much that I just never touch it again, so I want a solution that would not take me months to get working.
    That seems cheap, but the you need the receiver also. rfRXD0420/0920 $2.89 from MicroChip. LQFP package If you are doing a production run they would be great.
    But if it is a one or two thing....
    The cheapest/ease of use I know of is these
    http://www.rentron.com/remote_control/TWS-434.htm
    http://www.rentron.com/remote_control/RWS-434.htm
    All the need is an antenna and a PIC.
    I tested some and had no trouble at a half mile line of sight.
    Just my opinion.
    Dave, thank you!
    My problem is, that my customers will have for example 10-500 transmitters and 1 receiver and I want to go in production with it, so $1 would make a huge difference
    I just want to transmit a 15 digit ID, one at a time.
    Do you think I would easily get the Microchip rfPIC12F675K running?
    I see. Many units...
    I have not used the parts individually. Helped with a dev board setup. Seems pretty straight forward.
    Here is a sample code from Bruce
    http://www.picbasic.co.uk/forum/show...4830#post44830
    Sending the data should be easy enough. You will need a checksum or some other error checking.
    The basic code could be
    SEROUT2 PORTC.6, 16780, [ STR DATAOUT\16, $d, $a]
