Display Degrees of rotation.
Results 1 to 26 of 26
    Dec 2010
    Michigan
    Mark,
    I have come across that link a few days ago. I think I may use the CD drive motoronly due to it being mounted on a pcb that would lend to easy mounting to the tail of the rotor drive motor, plus it would only require 3 wires to run it. Will try to post pictures of what I a working with later then maybe all of this will make sense.
    Bob
    Dec 2010
    Michigan
    Default Re: Display Degrees of rotation.
    Thanks for all the replys.
    I ended up using a hall sensor and the magnets from a CD drive motor for the sensor part. I used a 16F1827 PIC, a 2x16 LCD and other hardware. I now have a rotor controller that will allow me to go from -90 of North to 360 rotation plus an additional +90 of north 540 total degrees of rotation. To give me a HOME position I used a IR emitter detector with a reflective strip to light an LED on the controller panel. I can increment/decrement the "GOTO" poition by either 1 or 10 degrees at a time. I am really happy.
    Bob
    Thumbs up Re: Display Degrees of rotation.
    Quote Originally Posted by Bobw55 View Post
    Bob
    Hi Bob,
    Lot's of Hams on this forum. Your project looks useful as all getout to me, might make a great article or entry into one of this forums contests. Food for thought. If you do not intend to make a commercial product, perhaps you would write it up with code and submit it.
    Dec 2010
    Michigan
    I may have to consider that.
    I only have a hand drawn schematic.
    Here is a picture of the almost completed project. I still need to finish the labeling.
    Mar 2011
    Los Angeles, California
    Hi Bobw55,
    As a ham (WB6NSN) I can appreciate the need to know where the antenna is pointed. One other possible solution is to use a compass module such as the R1655. Here is a link with everything: http://www.robsonco.com/Dinsmore/Untitled_5.html
    For me, I slipped the sensor into a plastic tube and sealed it.
    The accuracy is 1/10 of 1 degree.
    Quote Originally Posted by Ramius View Post
    Hi Bobw55,
    What a great idea!
    Ramius , My only concern would be the close proximity to the antenna during transmit. The flux coils may be over driven....
