Display Degrees of rotation.
Results 1 to 26 of 26
    Default Re: Display Degrees of rotation.
    Quote Originally Posted by Ramius View Post
    Hi Bobw55,
    As a ham (WB6NSN) I can appreciate the need to know where the antenna is pointed. One other possible solution is to use a compass module such as the R1655.
    What a great idea!
    Ramius , My only concern would be the close proximity to the antenna during transmit. The flux coils may be over driven....
    Mar 2011
    Los Angeles, California
    Hi Dave,
    Actually the R1655 sensor is actually 2 HAL effect transistors and a permanent magnet so there are no coils. The compass works next to a 5 watt 1.2GHZ transmitter with no effect. On the compass PC board the sensor is mounted right on top of the A/D converter to keep the connections as short as possible just to avoid any noise since the compass is in an R/C submarine with a lot of DC motors and there is a bypass capacitor on the same board with the sensor and A/D. I used two each 3-wire shielded audio cables between the compass and the PIC. I believe you would be just fine and you could also include some ferrite beads if you wish. Hope this helps, Ed
    Dec 2010
    Michigan
    I had thought about using a compass sensor. Still like the idea. Most I found were on the expensive side, not to mention I was just getting my feet wet messing with PICs and programming. Should I ever decide to redo things that may be the way to go. Would like to see some pictures as to how you mounted yours.
    Bob
