Wrong Frequency
Results 1 to 6 of 6
Thread: Wrong Frequency
    May 2008
    Italy
    You have to set the OSCCON register, since by default is set to 4 MHz and you define the osc as an 8 MHz one.
    Cheers
    Al.
    Aug 2008
    Portugal
    Thank you aratti for the fast answer to my problem. I changed the OSCCON register, and it worked at the desired frequency.
    Thank you once again!
    Thanks and Regards;
    Gadelhas
    Miami, Florida USA
    Hmmm , I thought the DEFINE OSC x takes care of the frequency registers. I'm just curious, will it work if the internal oscillator is defined first and then the frequency is defined after that? In the next code, I just swapped the order of the first two lines in gadelhas original code.
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _BOD_OFF
    Define OSC 8
    '                                PINOUT 1 = IN; 0 = OUT
                  '76543210
     TRISIO     = %00000001
                  '76543210
       GPIO     = %00000000
     ANSEL = 1  'GP0 ANALOG
     VRCON = 0  'VREF OFF
     CMCON0 = 7 'COMPARATOR OFF
     ADCON0 = %10000000  'RIGHT JUSTIFY - 128
     PR2     = %00011000 'SET 24 - 5000Hz - 8Bits
     T2CON   = %00000110 'TIMER2 ON - PRESCALER 1:16 - Max Duty Value 100 - 1% Step
     CCPR1L  = %00000000
     CCP1CON = %00001100 'PWM ON
    Anonymous
    The configs and the OSCCON register if using an internal OSC is for setting the hardware.
    The PIC will then run at that speed. Run at the speed of the external OSC or the internal setup.
    All
    DEFINE OSC X
    does is to tell PBP how fast the chip is running. DEFINE OSC X does not set the chips speed.
    Because the two are completely different things the order does not matter.
    Miami, Florida USA
    All
    DEFINE OSC X
    Ooh, I see. Dave thank you for your help.
    Anonymous
