					Hmmm  , I thought the DEFINE OSC x takes care of the frequency registers. I'm just curious, will it work if the internal oscillator is defined first and then the frequency is defined after that? In the next code, I just swapped the order of the first two lines in gadelhas original code.
	@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _BOD_OFF
Define OSC 8
'                                PINOUT 1 = IN; 0 = OUT
              '76543210
 TRISIO     = %00000001
              '76543210
   GPIO     = %00000000
 ANSEL = 1  'GP0 ANALOG
 VRCON = 0  'VREF OFF
 CMCON0 = 7 'COMPARATOR OFF
 ADCON0 = %10000000  'RIGHT JUSTIFY - 128
 PR2     = %00011000 'SET 24 - 5000Hz - 8Bits
 T2CON   = %00000110 'TIMER2 ON - PRESCALER 1:16 - Max Duty Value 100 - 1% Step
 CCPR1L  = %00000000
 CCP1CON = %00001100 'PWM ON
Anonymous
