LED fade without PWM command
Results 1 to 8 of 8
    Nick's Avatar
    Nick Guest
    Thanks Steve.
    I'm using PBP 2.45a to compile your code
    and I'm getting an error:
    "59: [235] Opcode Expected Instead of '_config'
    Does the code compile for you?
    Nick's Avatar
    Nick Guest
    I tried the suggested PWM built in PBP and it works pretty good.
    Here is the code I used to get a nice ramp up and down even with
    high brightness LEDs which are harder to control linearly.
    led VAR PORTB.5
    steps VAR WORD
    cycles CON 2
    ' Change limits for steps to play around 0 or 100% brightness
    ' Change steps for different duration of ramps
    ' Works good even with high brightness LEDs, harder to control linearly
    fade:
    up:
    For steps=0 TO 255
    PWM led,steps,cycles
    Next
    High led
    Pause 2500
    down:
    For steps=255 TO 1 STEP -1
    Next
    Low led
    Pause 2500
    GoTo fade
    Quote Originally Posted by Nick
    Thanks Steve.
    Nick this is caused by the @config line... simply remark this line.. This line set the configuration fuses for your PIC. If you're using PM instead of MPASM this will gives you this error message. See the FAQ about configuration fuses. Really handy stuff.
    Nick's Avatar
    Nick Guest
    I made the changes and everything works fine
    Thanks again Steve.
    ollim13's Avatar
    ollim13 Guest
    Red face Circuit
    Hallo I´m new in programming, is it possible to get the circuit for the programm from Nick.
    Thank you.
    Olli
    Dec 2003
    Wichita KS
    Hello Olli,
    All you have to do , is connect a diode to the pin in which you are working with... connect up your +/- voltage, and presto. No circuitry per se is required...
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. LCD will not start
  4. Strangw results when using PWM command
    Last Post: - 10th July 2006, 13:14
  5. Fade out an LED using PWM?
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 6th August 2004, 20:59
