IEEE 754 32bit floating point value.
Results 1 to 10 of 10
    Aug 2010
    Maryland, USA
    Adding to the confusion to try and shead some light. You say the number you get back could be 751, which would equal 75.1. how is this sent? is it :
    00000001 01110111, or is it
    00000111 01010001?
    The first being stright binary and the second being packed BCD I will assume the first. Now when you say you need a 32 bit, floating point answer, seems to me there must be some format to this. for instance, does the device you are sending it to expect the decimal to be in any special place? is it good with a 5 place decimal or does it assume 2 place? how does the receiving end expect to see the number? I mean 32 bit for tempreture is a bit much I think, could be 32767.32767 to -32767.32767 degrees! or something like that. Either way I don't want to live there!!!
    -Bert
    Sep 2008
    I used this information to read floats from an AB plc and it worked fine. There is a subroutine for Int to Float.
    http://melabs.com/resources/fp.htm
    Dec 2004
    nebraska
    thanks for the replys everyone,
    Ive been gone for a while and havent had time to suddy it all yet. Ill get back to it.
    Nick
    Miami, Florida USA
    Quote Originally Posted by shawn View Post
    Nick
    Shawn,
    It looks like we were trying to reinvent the wheel. Everything that you need is provided in the melabs.com link that Cobra_Phil mentions above.
    Anonymous
