IEEE 754 32bit floating point value.
Results 1 to 10 of 10
    Dec 2004
    nebraska
    Thanks for the answer Robert. I found some examples on the web and I understand it now. Has anyone ever done this on a PIC. It does look complicated, is there any other vriable type that would handle a decimal point in modbus rtu. It didnt look like it. Robert have you ever written a 32 bit floating point routine to pack a variable with pic basic pro. I would love some tips on how to get started. Or some links to posts in the forum
    Shawn
    Miami, Florida USA
    Quote Originally Posted by shawn View Post
    Shawn,
    No, I have never written a PBP program to convert a decimal number into a floating point. Do you know C language? In C18 you can declare a variable as a 32-bit float. However, it takes a lot of programming memory when you use float variables in C18.
    If you insist in writing this program in PBP, I would suggest to use Long vars in PBP for the 32-bit floating point numbers. It can be done, but it is something that won't be done in a single afternoon. I found some examples in the web to convert decimals to 32-bit floating point. The following link has some examples. Disregard the 8-bit floating examples, but you can study them as well since the idea is the same.
    http://sandbox.mc.edu/~bennet/cs110/flt/dtof.html
    Anonymous
    Bombay, India
    I have worked on the floating point library for the 8051. This is a converter I wrote in QuickBasic 4.5 to convert a floating number entered on the PC to floating point representation that can be understood by the micro controller. See if it will help you move ahead in your quest.
    To the best of my recollection, the format is
    8 bits biased exponent followed by 24 bits signed mantissa.
    The idea is to move the mantissa till you get a 1 bit in the highest position of the mantissa and accordingly change the exponent by the amount you moved the mantissa. Then remove the highest bit (it is implicit) and put in the sign bit for the mantissa. A 1 bit here means it is a negative number.
    That's all I can offer right now. I am a bit hazy on the details at the moment as it has been more than 10 years ago that I did this. If you need any help, let me know and I'll try to help.
    DIM Mant AS SINGLE, Expo AS INTEGER
    DIM bits AS INTEGER, Sign AS INTEGER
    PRINT "CFLT converter for text to float51 format"
    INPUT "Please enter the number : ", num
    IF num < 0 THEN
      Sign = 1
      num = -num
    END IF
    Mant = num
    Expo = &H80 + 24
    FOR bits = 1 TO 24
      IF (Mant AND &H800000) THEN EXIT FOR
      Mant = Mant * 2
      Expo = Expo - 1
    NEXT
    'remove the MSB if +ve
    IF Sign = 0 THEN
      Mant = Mant AND &H7FFFFF
    END IF
    PRINT "The floating point representation is  Exp, Mantissa"
    PRINT HEX$(Expo); ", "; HEX$(Mant)
    Aug 2010
    Maryland, USA
    Adding to the confusion to try and shead some light. You say the number you get back could be 751, which would equal 75.1. how is this sent? is it :
    00000001 01110111, or is it
    00000111 01010001?
    The first being stright binary and the second being packed BCD I will assume the first. Now when you say you need a 32 bit, floating point answer, seems to me there must be some format to this. for instance, does the device you are sending it to expect the decimal to be in any special place? is it good with a 5 place decimal or does it assume 2 place? how does the receiving end expect to see the number? I mean 32 bit for tempreture is a bit much I think, could be 32767.32767 to -32767.32767 degrees! or something like that. Either way I don't want to live there!!!
    -Bert
    Sep 2008
    I used this information to read floats from an AB plc and it worked fine. There is a subroutine for Int to Float.
    http://melabs.com/resources/fp.htm
    Dec 2004
    nebraska
    thanks for the replys everyone,
    Ive been gone for a while and havent had time to suddy it all yet. Ill get back to it.
    Nick
    Miami, Florida USA
    Nick
    Shawn,
    It looks like we were trying to reinvent the wheel. Everything that you need is provided in the melabs.com link that Cobra_Phil mentions above.
    Anonymous
