Question about using ASM interupt with PBP
Results 1 to 7 of 7
    Aug 2010
    Maryland, USA
    Default Question about using ASM interupt with PBP
    Before all the suggestions about using DT_INT, I have tried them, they work great, but not for my current app.
    I see in the book I just need to "DEFINE INTHAND SOMELABEL" to get PBP to place a jump at location 4 in memory.
    Then at the SOMELABEL routine, I ASM and write my code. Now my question is do I RETFIE at the end of my routine? then ENDASM.
    I don't need to think about how I got to SOMELABEL? It is a true GOTO and not a GOSUB placed at location 4?
    -Bert
    DT_INTS is ASM interrupts. If you can't get them to work in your app, writing your own probably won't help.
    Were you using PBP type handlers?
    You can use ASM type handlers without having to write the low level stuff yourself.
    Why do you think they won't work in your app?
    Aug 2010
    Maryland, USA
    http://www.picbasic.co.uk/forum/show...ge=2#post96731
    The link should take you to the top of page 2 in my thread "My project is starting"
    They do work, but end up being the only thing to work. I am jumping to the interupt at every line of code. This is not because they don't work, but I am GUESSING just too short of a timer. As My PIC (16F1947) has automatic context saving for the interupt AND I don't need to save any other stuff, I was thinking just do it the built in way.
    I would LOVE for you to help me to get DT_INT working for me in this app. I see the beauty in it and will use them when I can.
    The @int return in the handler is not really at the end of the comment. In fact the comment doesn't even exist in my program(the part in Red)
    BTW, I have no trouble with ASM, I am just determined to do things a little easier and learn PBP. But as I do, I find myself still thinking in terms of ASM.
    I am generally a lazy typer, and would rather code this:
    LATF = PORTA
    then this:
    MOVF    PORTA,0
    MOVWF LATF
    -Bert
    OK, I can see the difficulty there.
    5 uS isn't much to work with.
    I have been able to get your program from the other thread to work with just a few changes.
    By setting PR2 to 39, TMR2 doesn't have to be reloaded on each interrupt, saving 2 instructions.
    A TMR2 = PR2 match will reset the timer value and trigger the interrupt.
    The actual period is PR2+1 (40 instructions).
    The TOGGLE EN1 can be replaced with LATF = LATF ^ 1 which saves another 2 instructions because TOGGLE also sets the TRIS bit to output everytime.
    So after setting PR2 in your initialization ...
    PR2 = 39   ; set TMR2 period to 5 uS
    The interrupt handler looks like this ...
    '---[TMR2 - interrupt handler]--------------------------------------------------
    FiveMicroSec:
        LATF = LATF ^ 1   ; TOGGLE EN1
        CNT =CNT+1
        LATC = PORTA
    @ INT_RETURN
    There's still a couple instruction cycles left ... but to answer your original question, you can get a few more cycles back with straight ASM handlers.
    _________________________ _____________________________
    To do that, let's take the same handler and remove DT_INTS.
    DEFINE the ISR's routine (_FiveMicroSec).
    Set the TMR2IE, PEIE and GIE bits.
    Clear the INT flag at the end.
    And instead of @ INT_RETURN ... use @ RETFIE.
    PR2 = 39
    PIE1.1 = 1        ; Enable Timer2 interrupts
    INTCON.6 = 1      ; enable PEIE
    INTCON.7 = 1      ; enable GIE
    T2CON = %00000100 ; Start Timer2
    DEFINE INTHAND _FiveMicroSec
    FiveMicroSec:
        CNT =CNT+1
        PORTC = PORTA
        PIR1.1 = 0          ; clear the interrupt flag
    @ RETFIE
    That should give another 20 instruction cycles.
    Don't go crazy in the ISR.
    You can only use PBP statements that DO NOT change PBP's system variables.
    ___________________________ _________________________________
    On a different note ... You shouldn't use LATx.x with HIGH, LOW, TOGGLE or any other PBP commands.
    Direct assignments to LATx are OK, but when PBP tries to set the tris bit, referenced to the LAT bit, it overwrites the wrong registers.
    PBP commands that accept Pins, only work properly with PORTx.x, not LATx.x.
    HTH,
    Aug 2010
    Maryland, USA
    Talking Wow!
    So much learned here!
    Now I get what PRx is for. Sort of feel a little Doh over that. I prolly would have gone years without seeing it. And its so much more intuitive. (number of cycles - 1) THANK YOU!
    I love the toggle replacement
    Not only did you answer my original question, but you also did the work for me. To be sure, I will not be going crazy in the ISR, in fact the only thing it needs to do is PORTC = PORTA. the rest is for debugging and will not be in the final program. I may keep a counter in there for something.
    Is it safe to assume DT_INT cost about 20 cycles when not used with PBP handler? This is just good to know.
    I must admit, I'm not sure I get the rules for using LATx, but easy enough to just not use it at all. I suppose you are saying LATx=something is fine, but not much else.
    I think I am most excited about the PRx knowledge.
    -Bert
    With the 16F1's that's about what it takes to get IN and OUT of DT_INTS.
    I didn't count it to the exact number of cycles. It can change depending on the setup.
    I must admit, I'm not sure I get the rules for using LATx, ...
    Throughout the manual you'll find this statement frequently ... "Pin is automatically made an input" or output.
    So those commands will try to set the TRIS bit each time it executes.
    When you give it a PORTx.x pin, PBP finds the TRISx.x bit by adding $80 to the ports address.
    Here's the .LST from a LOW PORTA.0
                          00194 ; C:\ISIS\5US_INTS\ASMCNCGUY5US.PBP     00076   Z0001D  LOW PORTA.0
    001F                  00195 Z0001D
                          00196         LOW?T   _PORTA??0
    001F   100C               M         bcf     PORTA,  000h
    0020   0021               M         movlb   (((PORTA) + 80h)) >> 7
      00000001                M PREV_BANK = (((PORTA) + 80h)) >> 7
    0021   100C               M         bcf     ((PORTA) + 80h), 000h
    But if you give it LATA.0, adding $80 makes it point to ANSELA instead of TRISA.
    The TRIS bit doesn't get set, and the ANSELA gets changed.
    And now you know why not to use LATx.x as a pin.
    Knowledge is Power, and Power is intoxicating ...
    Please drink responsibly.
