Push Button 'Menu' to Choose Variable.
Results 1 to 8 of 8
    The code that I posted in its existing form is not suitable for interrupt use. It was posted to get you started. Consult the "ON INTERRUPT" statement in the PBP manual to see how you could modify for that purpose.
    Changing the polarity of that statement would only be valid if the button pulled up to +Ve and the pin normally idled high.
    Feb 2005
    Essex, UK
    I believe it wasn't working properly due to the Interrupt settings which i have now disabled on PortB.0.
    I have it working the way i want apart from one thing.
    It recognises the push switch, displays the appropriate PWM and then if it reaches 9 goes to 1 again. Also, if no input for 5 seconds it starts the flashing sequence (just to signal the end of the 5 seconds).
    How does one get the LEDs to stay in their PWM routine until the switch is pressed again, without using Interrupts. When the swicth is pushed it goes to the appropriate PWM routine but after the PWM cycle, the LED goes off.
    Here is the code.
    MyNumber    VAR Byte	' Variable 1-9
    MyTimeOut   VAR Byte	' 5 second Timeout (100 loops of 50mS)
    Red         VAR PORTB.1 ' All LEDs
    Green       VAR PORTB.2 ' Connected between
    Blue        VAR PORTB.3 ' RC pins and ground
    Orange      VAR PORTB.4
    DISABLE INTERRUPT
    MyButton    VAR PORTB.0 	' Pin goes LOW when Button pressed
    MyNumber=1		' Power-On with this starting value
    MyTimeOut=0		' TimeOut starts from zero at Power-Up
    	While MyTimeOut<100
            If MyButton=0 then
    			gosub mynumberpwm
                MyNumber=MyNumber+1
    			If MyNumber>9 then MyNumber=1
                MyTimeOut=0
    			Pause 50
    				' This Pause DEBOUNCES Button - do not remove it
    			While MyButton=0:Wend
    				' Wait here if Button held down
    			MyTimeOut=MyTimeOut+1
    			Pause 50
    				' This Pause is the Timeout Pause
    		Wend
        high Orange
        low Orange
    MynumberPWM:
        If Mynumber = 1 then PWM Red,1,255
        If Mynumber = 2 then PWM Red,25,255
        If Mynumber = 3 then PWM Red,255,255
        If Mynumber = 4 then PWM green,1,255
        If Mynumber = 5 then PWM green,25,255
        If Mynumber = 6 then PWM green,255,255
        If Mynumber = 7 then PWM BLUE,1,255
        If Mynumber = 8 then PWM BLUE,25,255
        If Mynumber = 9 then PWM BLUE,255,255
    Many thanks,
    How does one get the LEDs to stay in their PWM routine until the switch is pressed again, without using Interrupts? When the swicth is pushed it goes to the appropriate PWM routine but after the PWM cycle, the LED goes off"
    Unless you are able to write a program with an "active real-time" loop that executes continuous PWM (I do recall posting an example of such code dimming multiple LED's continuously sometime ago), the only option you have is chosing a PIC with multiple hardware PWM.
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  3. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  5. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
