I have been trying to get the ICD to connect/work and have had no luck.
I get a message "MIcroCode Studio is unable to connect to the target PIC microcontroller using the assigned serial port."
I have a serial cable going to a MAX 232 chip, following the schematic in the documentation.
Here is my code:
My configs:Code:INCLUDE "modedefs.bas" include "ALLDIGITAL.pbp" DEFINE LOADER_USED 1 OSCCON =$60 'clock speed ' DEFINE OSC 4 LED VAR PORTB.0' Assign name "LED" to PORTB.0 mainloop: High LED ' Turn on LED connected to PORTB.0 Pause 500 ' Delay for .5 seconds Low LED ' Turn off LED connected to PORTB.0 Pause 500 ' Delay for .5 seconds Goto mainloop ' Go back to loop and blink LED forever End
Any Ideas?Code:LIST p = 18F4550, r = dec, w = -311, w = -230, f = inhx32 INCLUDE "P18F4550.INC" ; MPASM Header __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L __CONFIG _CONFIG1H, _FOSC_INTOSC_HS_1H & _FOSC_INTOSCIO_EC_1H & _FCMEM_OFF_1H & _IESO_OFF_1H __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
