Hex digit verification
Results 1 to 6 of 6
    Dec 2005
    Salt Lake City, Ut, USA
    Default Hex digit verification
    Hey guys,
    As you've gathered from my "parts sourcing" post, I am in the heat of the battle on my "code sniffer" project. I thought I had the code to check for valid digits licked but then...doh!
            EEAddress=414
            I2CREAD I2cData,I2cClock,$A0,EEAddress,[CheckPanelDigit]
            IF CheckPanelDigit < 153 THEN
                EEAddress=415
                    I2CREAD DPIN,CPIN,$A0,EEAddress,[CheckPanelDigit]
                        IF CheckPanelDigit < 153 THEN      'BETWEEN HEX 00 AND 99
                            Goto ConcordExpress
                            goto SnifferErr
                goto SnifferErr
    As I am checking for "valid" digits, I figured I could just make sure they are below DEC 153 (Hex 99). Well, what if I happen to get a "8E" (DEC 142)? The code will execute, which I can't allow to happen. I guess the easiest way to explain it is: the hex received must have 2 valid digits in it, 0-9.
    Is there a routine, or a bit of math trickery I can perform to do the verification of the hex pair?
    Whew, I think I confused myself after reading this post!
    I hope it makes sense to one of you.
    Thanks guys,
    Chris
    Dec 2005
    I think this will work...
    <<<SNIP>>>
            EEAddress=0
            pause 50
            gosub TestHex
            if ValidDigits = 1 then
                EEAddress=1
                    pause 50
                    gosub TestHex
                            Goto Vista
                            goto SnifferErr
                goto SnifferErr
            goto MainLoop
    SnifferErr:
        LCDout $fe, 1
        LCDout $fe, 2,   "       ERROR        "
        Lcdout $fe, $C0, "PANEL NOT RECOGNIZED"
        Lcdout $fe, $94, "CHECK CONNECTIONS OR"
        Lcdout $fe, $D4, "SELECT CORRECT PANEL"
    GOTO MainLoop
    TestHex:
        ValidDigits = 0
        TestDigit = CheckPanelDigit & $0F           ' Isolate the lower nibble
            if TestDigit < 10 then                  ' First digit is 0-9
                TestDigit = CheckPanelDigit >> 4	' move high nibble to low nibble
                if TestDigit < 10 then              ' Second digit is 0-9
                    ValidDigits = 1                 ' Set flag for good digits
    How does that look? Am I thinking along the correct lines?
    Thanks guys,
    Chris
    It looks to me like you have a two digit BCD value packed into one byte, is that correct?
    I'm sure there are better and more clever ways of doing it but this seems to do what I think it is you're asking about:
    If (CheckPanelDigit & 15) < 10 AND (CheckPanelDigit & 240) >> 4 < 10 then
    '...more code here
    Try it out and see if it does what you want.
    Dec 2005
    Thanks Henrick,
    Sure is prettier than my code . As far as the BCD in a byte, yep, pretty much it. It can be any Hex digit in there. So, I just need to make sure each nibble in the byte is a number, not a letter. I'll give your code a shot in a bit. I'll have to intentionally read from the wrong address to make a go of it. On another quick note, would you have a quick and easy, down and dirty way to "flip" the 2 hex characters around? ie: HEX59 becomes HEX95. One of the panels I am working on stores its codes "backwards". Sneaky 'lil buggers. I need to flip 'em so I can display them on the lcd. I've got a routine working now, the low nibble - high nibble way, but just wondering if there was a better way?
    Thanks again,
    Chris
    Hi Chris,
    You actually posted while I was typing my reply - I didn't see your own response.
    Anyway, if you can afford two new bytes, lets call them Ones and Tens then you could do something like this instead (it produces slightly smaller code:
    Ones VAR BYTE
    Tens VAR BYTE
    Ones = CheckPanelDigit & 15
    Tens = (CheckPanelDigit & 240) >> 4
    If Ones < 10 AND Tens < 10 then
    '....more code here
    This will then allow you to do something like:
    SwappedValue VAR BYTE
    SwappedValue = Ones << 4 + Tens
    Which swappes the order of the high and low nibble in the byte.
    Dec 2005
    Very cool Henrick, thanks. When I get a second to try that code, I will. I'll report back asap.
    Thanks again,
    Chris
