Code Improvement
Results 1 to 6 of 6
    Aug 2008
    Portugal
    Hi Everyone, and many thanks for the answers to my post!!!
    Hi follow your opinions and i change the code to this;
    '*  Name    : PWM.BAS                                           *
    '*  Author  : Gadelhas                                          *
    '*  Notice  : Copyright (c) 2010                                *
    '*  Date    : 28-11-2010                                        *
    '*          : PIC12F683  + MICROCODE + EASYPICV6                *
    '                         INCLUDE's e FUSES
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _BOD_OFF
     Define OSC 8
    '                               VARIÁVEIS
     AdcValue var word: AdcValue=0
     I        var word: I=0
     Sample   var word: sample=0
    '                       REGISTOS E PINOUT 1 = IN; 0 = OUT
                  '76543210
     TRISIO     = %00000001
                  '76543210
       GPIO     = %00000000
     ANSEL = 1  'GP0 AANALOG
     VRCON = 0  'VREF OFF
     CMCON0 = 7 'COMPARATOR OFF
     ADCON0 = %10000000  'RIGHT JUSTIFY - 128
     PR2     = %00011000 'SET 24 - 5000Hz - 8Bits
     T2CON   = %00000110 'TIMER2 ON - PRESCALER 1:16 - Max Duty Value 100 - 1% Step
     CCPR1L  = %00000000
     CCP1CON = %00001100 'PWM ON
    '                              NOMES PINOUT
     POT1      VAR GPIO.0
    '                              DEFINIÇÕES
     DEFINE ADC_BITS 10     ' Set number of bits in result
     DEFINE ADC_CLOCK 3     ' Set clock source (rc = 3)
    '                             INICIO PROGRAMA
       gosub ADC
       CCPR1L.7=AdcValue.9
       CCPR1L.6=AdcValue.8
       CCPR1L.5=AdcValue.7
       CCPR1L.4=AdcValue.6
       CCPR1L.3=AdcValue.5
       CCPR1L.2=AdcValue.4
       CCPR1L.1=AdcValue.3
       CCPR1L.0=AdcValue.2
       CCP1CON.5=AdcValue.1
       CCP1CON.4=AdcValue.0
    GOTO MAIN
    '                          SUB-ROTINAS
    ADC:
       for I = 1 to 15
            ADCON0.1 = 1
            Not_Done:
            if ADCON0.1 = 1 then not_done
            adcin 0,AdcValue
            sample = AdcValue  + sample
        next I
        AdcValue = (sample/163)
        sample=0
    The code works great. Initially it had 288 words, after change went to 213 words.
    Is it possible to improve this piece of code?;
       CCPR1L.7=AdcValue.9
       CCPR1L.6=AdcValue.8
       CCPR1L.5=AdcValue.7
       CCPR1L.4=AdcValue.6
       CCPR1L.3=AdcValue.5
       CCPR1L.2=AdcValue.4
       CCPR1L.1=AdcValue.3
       CCPR1L.0=AdcValue.2
    Is this correct?
    >>1 is the same as devide by 2
    >>2 is the same as devide by 4
    >>3 is the same as devide by 8
    >>4 is the same as devide by 16
    >>5 is the same as devide by 32
    >>6 is the same as devide by 64
    >>7 is the same as devide by 128
    >>8 is the same as devide by 256
    and
    <<1 is the same as multiply by 2
    <<2 is the same as multiply by 4
    <<3 is the same as multiply by 8
    <<4 is the same as multiply by 16
    <<5 is the same as multiply by 32
    <<6 is the same as multiply by 64
    <<7 is the same as multiply by 128
    <<8 is the same as multiply by 256
    Thanks once again to everyone!!
    Thanks and Regards;
    Gadelhas
    Sep 2005
    Campbell, CA
    One thing you could do is -
    CCPR1L = AdcValue >> 2
    Charles Linquist
