'// DS1337 and test program
'// Using the PIC16F887
'// From Dave Mackarit FUNCTIONAL
'// Define section //
'@ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
OSCCON = %01110000 '8 Mhz
DEFINE OSC 8
ANSELH = 0
'// LCD configuration //
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus RB.4, RB.5, RB.6, RB.7
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
DPIN VAR PORTC.4 'I2C DATA PIN
CPIN VAR PORTC.3 'I2C CLOCK PIN
Write_Address VAR WORD
i var byte
j var byte
bat var byte
Battery_Charge_Counter var byte
' -------------- RTC definitions -----------------
RTC CON %11010000
SecReg CON $00 ' seconds Write_Addressess (00 - 59) ' MSB of SecReg must be set to a 0 to enable RTC
ContReg CON $0E ' control register
cntrl CON %00000000 ' sets the SQW/OUT to 1Hz pulse, logic level low
I2CWRITE DPIN, CPIN, RTC, ContReg, [cntrl]
' The variable below holds the values entered:
' entered by the user
sec VAR BYTE : mins VAR BYTE : hr VAR BYTE : day VAR BYTE :date VAR BYTE : mon VAR BYTE : yr VAR BYTE
Battery_Charge_Counter = 0
PAUSE 1000
GOSUB SET_RTC
Write_Address = 0
Mainloop:
lcdout $FE,1, "Appuye sur Record"
lcdout $FE,$C0, "ou sur Show"
if PORTC.6 =0 then
GOSUB READ_RTC
Write_Address =0
I2CWRITE DPIN,CPIN,$A0,Write_Address,[sec,mins,hr]
PAUSE 10
Write_Address = Write_Address +7
Battery_Charge_Counter = Battery_Charge_Counter + 1
Endif
if PORTC.7 =0 then
bat = 0
j=1
for i=0 to Battery_Charge_Counter
I2CREAD DPIN,CPIN,$A0,bat,[sec,mins,hr]
PAUSE 10
LCDOUT $FE,1," Time ",DEC3 j
LCDOUT $FE,$C0,"time ",DEC Battery_Charge_Counter,":", HEX2 hr, ":", HEX2 mins, ":", HEX2 sec
PAUSE 2000
bat = bat +7
j= j + 1
next i
Endif
GOTO Mainloop
READ_RTC:
I2CREAD DPIN, CPIN, $D0, SecReg, [sec,mins,hr,day,date,mon,yr]
SET_RTC: ' Do once at startup
yr = $3
mon = $5
date = $05
sec = $09
mins = $04
hr = $02
I2CWRITE DPIN, CPIN, $D0, SecReg, [sec,mins,hr,day,date,mon,yr]
