New an what to know what board is best to start
Results 1 to 14 of 14
    Unhappy New an what to know what board is best to start
    Ok so I'm new to PICs (although i program blackfin dualcore ADSP BF561 for a job =P) and I really want to learn more PIC stuff for my own little projects. I am a C programmer. Which platform do you think is better:
    EasyPIC5 or
    QL200?
    I have a windows 7 and a ubuntu machine. EasyPIC5 seems better but with fewer devices included onboard but it seems to support a wider range too =S
    Any help would do as I am new to PICs. I hope to be a regular poster as I have quite a range of projects I want to work on.
    Dec 2005
    Salt Lake City, Ut, USA
    Hello, and welcome.
    I am by far and a way not a PIC pro like some of these fine ladies and gentleman here, but I can say that this "hobby" is highly rewarding, especially with the assistance of the folks here.
    Certainly not to be taken as a smart-**s answer to your question, I started, and continue to use a simple breadboard. It has served me pretty well in my projects, and they're cheap too . I am sure they're not quite as "cool" as a pre-built board, but heck, they work.
    Good luck, and happy coding,
    C
    malc-c's Avatar
    malc-c Guest
    I started with a PicKIT1, then a JDM (several in various designs) then an ICSP USB programmer, and a cheap breadboard. But then purchased an EasyPIC5 board and haven't looked back.
    I still breadbaord some parts of a project, but tend to use the additional plug in boards where possible, makes life simple - For rapid re-programming whilst developing the code the EP5 (or 6) is ideal.
    Miami, Florida USA
    Like kevlar129bp, I always use a breadboard for my projects. In fact, I have never used a development board before . They are usually very expensive. You can accomplish most of your projects just by using a breadboard and some 22AWG solid wire to make the connections.
    Anonymous
    Thanks a lot guys. I have been using breadboard thus far but my problem is with the scale of projects I am looking to do it would very quickly become a tangled mess of fury and I wouldnt be able to keep track of what went where in the event of a wire coming away. Having a development board with just a few simple ports would make things a lot easier and I can just build the unique sections on bread/proto-board. After it tests out ok then transition the sections onto proto and then develop the next bit. My first project looks to be multi-PIC (around a half dozen) due to distance constraints as well as functional division so something a little mire hardcore id definitely needed.
    Sounds like the dev board you need would be best if it was custom built. Build it your self.
    Then you have what you need/want.
