DS1904 RTC - How to Convert Binary Time into Real Time/Date?
Results 1 to 8 of 8
    Aug 2010
    Maryland, USA
    Default Sorry
    I should have been more clear. I ment to say the 32 bit number represents the number of seconds since you sent it the command to reset the count, AND turn the OSC on. This thing looks to be a 32 bit counter, with each bit representing 1 second. I am not sure if it can be pre-set, or if you just have to know what time it is when you turn the OSC on.
    EDIT: Went back and read the datasheet again, yes you can write current time data to it. The most important thing is to realize it is all referenced to some known time. It just gives the number of seconds since then. I don't understand how it can be "syncronized" with the PC clock, this implies both use a reference system and they are the same
    -Bert
    Hi Bert.
    The point that confussed me more was that the chip was not set by me. It was set by Maxim or another person far far away from me in a different time zone, before winter time.
    As you can see by the attached picture above, it has 0-1 seconds difference from my PC! Amazing. There must be a trick.
    I found this C program but could not understand what really does.
    void loop(void) {
      byte i;
      byte present = 0;
      byte data[8];
      byte addr[8];
      uint32_t timestamp;
      int seconds = 0;
      if ( !ds.search(addr)) {
    	//Serial.print("No more addresses found.\n");
    	ds.reset_search();
    	delay(500);  // for readability
    	return;
      present = ds.reset();
      ds.select(addr);
      ds.write(0x66,1);   // read RTC
      for ( i = 0; i < 5; i++) {
        data[i] = ds.read();
    	timestamp = data[1];
    	timestamp = timestamp << 8;
    	timestamp |= data[2];
    	timestamp |= data[3];
    	timestamp |= data[4];
    Serial.println(timestamp);
    delay(1000);
    Aug 2010
    Maryland, USA
    Hi Bert.
    That is quite incredible! I dont get how the maxim reader could know when the timer was started
    As for the code snippit, I don't know C, but it appears to just read the data into an array, and display it.
    -Bert
    Yes it uses an array and does some oring and shifting.
    I really have not quite understood the logic behind it.
    A couple of days say Maxim for the AN to be approoved.
    Will see...
    Update from Maxim.
    Well, finally the counter is pure binary and user have to set a referene time stamp.
    So far OK. But how on earth can one calculate the date, months, leap years etc?
    If anyone interested in the details of the AN from Maxim, PM. Code examples are in assembly though.
