Hi Ioannis,
My application is simple, it just read the potentiometer / analog pins and then output the pulse accordingly.
Usually I put a hardware RC filter between the pots and the pins. It serves as delay
Code:'PIC 12F683 OSCCON = $60 ' Internal oscillator frequency 4 Mhz TRISIO = %00000011 ' Set TRIS to all input ANSEL = %00000011 ' Analog channel RA0 & RA1 ADCON0= %00000000 ' VDD as VREF CMCON0 = 7 DEFINE ADC_BITS 8 ' ADC resolution 8 bit DEFINE ADC_CLOCK 1 ' Set clock source (rc = 1) DEFINE ADC_SAMPLEUS 11 ' Sampling time 11ms anpin0 CON 0 ' Analog port pin RA.0 anpin0val VAR byte ' Value digital 0 - 255 anpin1 CON 1 ' Analog port pin RA.1 anpin1val VAR byte ' Value digital 0- 255 PAUSE 1000 LOOP: adcin anpin0,anpin0val adcin anpin1,anpin1val pulsout porta.4,anpin0val pulsout porta.5,anpin1val pause 10 goto loop
