FillMem or ClearMem
Results 1 to 10 of 10
    Hangover, Germany
    Red face FillMem or ClearMem
    I'm just coding a PIC18F-projekt and there is the need to clear some Arrays or so...
    What's about a ClearMem-command (or macro), because it is smarter then a "FOR I=0 to 15:Array[I]=0:Next I"-monster ?
    Are there any macros to use ?
    And what about a sizeof-function ????
    Not much help I'm afraid but anyway,
    CLEAR will set all RAM registers to zero. I don't know of a way to selectively clear RAM other than manually doing it, for example with a FOR-NEXT loop like you show.
    I'm not sure a SizeOf function would make much sense since arrays can't dynamically resize themself in PBP, you declare them as n bytes (or bits or words or longs) and they stay n bytes long. If you're storing a string for example you can create a subroutine to itterate thru the array and look for your end-of-string character. Could you elaborate a bit on what you need it for, perhaps someone can make a sugestion on how to do it.
    For PBP 2.60 ...
    MyArraySize   CON 32                    ; SizeOf
    MyArray       VAR BYTE[MyArraySize]     ; The Array
    ARRAYWRITE  MyArray,[REP 0\MyArraySize] ; Clear Array
    Hangover, Germany
    Cool
    I've done some own work, but it is not tested:
        asm
    ClearMem macro Array,Size                           ;Macro um Speicher zu löschen
        lfsr 0,Array
        movlw Size
        clrf POSTINC0
        decfsz WREG
        bra $-2
        endasm
    Any hints ?
    Hangover, Germany
    Lightbulb
    For PBP 2.60 ...
    Does this build a loop, or is there a "heavy load" of data in the code ?
    I work with PBP 2.50C.
    You need PBP 2.60 to use ARRAYWRITE.
    Quote Originally Posted by BigWumpus View Post
    Yes, it will use a loop (with 2.60).
    And in your macro above ...
    Since it uses the LFSR instruction, it will only work on 18F's.
    And 18F's are addressed by bytes instead of words, so I think the bra $-2 would need to be bra $-4.
    Otherwise, it should work.
    Hangover, Germany
    Wink
    Yes - that is know, the tiny 16Fs doesn't have so big tasks to do ... ;-)
    No - the datasheet uses a bra $-2 too and Picbasic compiles:
    000C12 0003               M loop    sleep
    000C14 D7FE               M         bra     loop
    the same way as
                          03868  ClearMem _bTier,_lTier                    ;Tier-Buffer löschen
    000F46 EE01 F042          M     lfsr 0,_bTier
    000F4A 0E20               M     movlw _lTier
    000F4C 6AEE               M     clrf POSTINC0
    000F4E 2EE8               M     decfsz WREG
    000F50 D7FE               M     bra $-2
    So, I think it will work for me...
    the same way as
    In the "sleep" example, the branch is going to the instruction immediately before the bra.
    In your macro, the bra needs to jump 2 instructions up to the clrf POSTINC0.
    So it will need to be -4.
    Hangover, Germany
    Unhappy
    S*it
    to late - to much wine
