Also, from the manual of the PIC16F88, there are 256 bytes allocated to EEPROM. I may need more. since I want to include 150 charge time and 150 discharge time.
Each charge time has a memory position for the seconds, minutes, hours, and day:
Voltage_Charge_time_RTCSec var byte[150]
Voltage_Charge_time_RTCMin var byte[150]
Voltage_Charge_time_RTCHour var byte[150]
Voltage_Charge_time_RTCDay var byte[150]
Voltage_DisCharge_time_RTCSec var byte[150]
Voltage_Discharge_time_RTCMin var byte[150]
Voltage_Discharge_time_RTCHour var byte[150]
Voltage_Discharge_time_RTCDay var byte[150]
so I need 1200 bytes OOOOO !! I guess!!
