Capturing Text File in Hyperterminal
Results 1 to 5 of 5
    John,
    What are you using to view the text file?
    Some programs expect to see the carriage return first.
    (13,10) instead of (10,13).
    Darrel
    Feb 2005
    Indiana
    Darrel,
    Thanks, I used 10,13 because that is the sequence I amusing to run a 16x2 LCD and displaying the same data that I wanted to capture in a text file using Hyperterminal. The next thing I want to do is run a VB program to display a/d input values.
    I'll try 13,10 this evening.
    John
    JRudd
    Italy
    Try with a serial modem.
    TYPE:
    ati3
    (+ press enter key)
    The modem will send you back its model number and sw version.
    Example:
    ati3
    SupraExpress 56e Memory s1.00-052099b
    OK
    In the captured file at the end of the lines you will see 0D 0A.
    Luciano
    If you have VB6 & SoftWire, you an make your own terminal program & A/D logging applicaion.
    Here's one with a strip chart, analog meter & a few more bells & whistles with the VB & PBP source code http://www.rentron.com/PicBasic/AD_Log.htm
    If you don't have SoftWire you can download if free of charge here http://www.softwire.com/swdownload/softwiredownload.htm
    -Bruce
    tech at rentron.com
  1. load .hex file in PIC with hyperterminal
    By irenuska23 in forum General
    Last Post: - 1st September 2009, 09:52
  2. The ultimate include file
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 26th January 2007, 19:35
  3. Help with sending text file from pic
    By isaac in forum Serial
    Last Post: - 15th August 2006, 20:01
  4. Capturing Information on the hyperterminal
    By moramlik in forum General
    Last Post: - 17th August 2005, 11:52
  5. Writing serial data to text file
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2005, 22:09
