Lookup Tables
Results 1 to 8 of 8
Thread: Lookup Tables
Threaded View
  1. #3
    May 2008
    Italy
    Dave, is it with the last version of PBP that you can use 1024 variables in lookup2 table?
    With mine I am limited to 256 for 18fxxxx
    Since your table is linear, with these two lines of code you can do without the rather large table:
    If TXI > 200 Then TXI = 0
    TXIU = 2500 - (TXI * 10)
    Checking the regression of your data, most of the time you discover that you can do without the lookup table.
    Nick, post your thermistor table convertion and I will check if it is feasible.
    Cheers
    Al.
