I2C storage issue
Results 1 to 4 of 4
    malc-c's Avatar
    malc-c Guest
    Not sure if it's what you are after, but (thanks to other forum members) use the following routine to place the data from a DS1307 into variables which are then used to compare set times and alarms, and these are then saved in the memory part of the PIC and recalled in the event of a power failure
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]  ; read DS1307 chip
    timeH=(RTCHour>>4)                               'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)                         'convert the BCD format of the mins register and store in variable timeM
    Dec 2005
    Or use an ST M41T81 in place of the DS1307. It automatically stores a timestamp whenever it goes on battery power allowing you to track power failure durations.
    Sep 2006
    The way I see its going towards array and long!!, unless there is another method.
    A simpler description of what I am looking is:
    I2Cread time1
    record time1
    ...code...
    I2Cread time2
    record time2
    ...code...
    I2Cread time3
    record time3
    ...code...
    So I can keep 100 different times
    K
