Menu selection
Results 1 to 8 of 8
Thread: Menu selection
    Sep 2006
    Default Menu selection
    OOOoookk
    Here it is. I am doing something and I am not sure how to..
    Ok I have a while loop, .. well for starters I have two button, 1-Start 2-go th the recorded time
    here is the while loop:
    While PORTB.2 != 1 ' if start button is not push do this loop
    While voltage_percent != 100 ' Charge the battery
    Gosub Charge_TwelveVolt
    Gosub Battery_Charging 'LCD out battery charging and percentage
    Wend
    Gosub Wait_60_Minutes 'wait 60 min
    While voltage_check <= 325 ' DisCharge the battery until its empty
    PORTB.3 = 1 'Turn relay ON, Lights will turn on
    I2CREAD SDA,SCL,$D1,$00,[STR DB0\8] ' Read 8 bytes from DS1307
    Gosub Check_voltage 'Check battery voltage, stay in this loop while it is not empty
    if (voltage_check <= TwelveVoltLimit) and (voltage_check > 325) then
    voltage_percent = (((voltage_check -325) * 3500 ) / 100 )
    if (voltage_check <= 325) then
    voltage_percent = 0
    voltage_percent = 100
    Gosub Battery_DisCharging 'LCD out the battery discharge information
    Voltage_Array_Charge_time(Battery_Cycle_Counter) = timer_time
    Voltage_Array_Discharge_time (Battery_Cycle_Counter) = timer_time
    Battery_Cycle_Counter = Battery_Cycle_Counter + 1
    Wend
    Wend
    'Now we are of the loop and
    'Show time battery discharge times chronologically. You have a button that goes through ll 'the times that has been recoded in the array.... and if no button is selected for 15 seconds, then the program returns to While PORTB.2 != 1 loop This is where I have no idea what to do..
    help ?
    maybe I am too sleepy
    K
    Not sure what you are asking...
    START:
    ###SNIP####
    Wend
    Wend
    GOTO START
    Sep 2006
    Ok basically I am looking for :
    The LCD module will show the discharging/charging percentage of the battery.
    The time of each discharge and charge cycle are accumulated in an array.
    when the user hit a button, it will put him into a menu. On another button the user can go through the array and view the charge dicharge time one by one. When no selection is done for 15 seconds, The program returns to the previous state.
    K
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by lerameur View Post
    K
    I use something similar in one of my projects - uses a 4 x 20 LCD
    mainmenu:
    LCDOUT $FE,2,"Main Menu"
    lcdout $FE, $C0, "Select Option"
    IF Option = 1 THEN lcdout $FE, $D4, "option 1  "
    if option = 2 then lcdout $FE, $D4, "option 2   "
    if option = 3 then lcdout $FE, $D4, "option 3  "
    if option = 4 then lcdout $FE, $D4, "option 4 "
    if option = 5 then lcdout $FE, $D4, "option 5  "
    if option = 6 then lcdout $FE, $D4, "option 6  "
    IF !H_butt THEN Option = option + 1
    pause 200
    if option >6 then option = 1
    If option = 1 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    Gosub SetButtonRelease
    goto  option_one
    If option = 2 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto option_two
    .... etc etc for all remaining options
    To do the time out you could use something like
    	Pause 1			' Kill 1mS
    	TimeOut=TimeOut+1
    	If TimeOut>20000 then goto mainprogram
    Obviously you need to either set or use your own variables
    Hope that helps
    Sep 2006
    Hi, the problem is that I need sub menus.
    This is the end of my program which I am trying to create menus and sub_menus
    PORTC.3 is use to switch to the next result, but if PORTC.3 is not press for 10 seconds it returns to the previous condition now shown here. My problem is making the menus and the 10 seconds limit.
    Anyone can help me ???
    K
    'Show time battery discharge  times, Here is hte result of a push on PORTC.3
                lcdout $FE,1, "  Appuyé sur Suivant  "
                lcdout $FE,$C0, "Press on next"
    if PORTC.3 != 1 then      'show the array time- NEXT button; PORTC.3 is the 'Next' button
        if Battery_Cycle_Discharge_Counter = 0 then
                lcdout $FE,1, " Aucun test "
                lcdout $FE,$C0, "No test"
        Endif
        if Battery_Cycle_Charge_Counter = 0 then
        Endif
        if Battery_Cycle_Charge_Counter > 0 then ' Only display if there is something in the array. Show the time for 10 seconds, if PORTC.3 is not press then go back to Mainloop
            BCCC = Battery_Cycle_Charge_Counter
            Counter = 0
                While BCCC != 0
                    While PORTC.3 != 1        'Hold the time on LCD until 'NEXT' button is pushed again or max 10 seconds
                        lcdout $FE,1, " Charge time: " dec Counter
                        lcdout $FE,$C0, dec Voltage_Array_Charge_time_RTCDay[Counter]," jour ",dec Voltage_Array_Charge_time_RTCHour[Counter],dec Voltage_Array_Charge_time_RTCMin[Counter],dec Voltage_Array_Charge_time_RTCSec[Counter]
                        Gosub Hold_menu_1 'Pause until PORTC.3 != 1  ..or ten seconds
                    Wend
                        BCCC = BCCC - 1
                        Counter = Counter + 1
                Wend
        Endif
        Gosub Hold_menu_2
            ' if PORTC.4 != 1 then      'show the array time Previous....to be completed... similar to NEXT menu
    '/////// Hold_Menu_1  ////////
    Hold_Menu_1:
    for i = 1 to 100
            goto Here_to_return
        Endif
    next i
    Goto mainloop
    Here_to_return
    '/////// Hold_Menu_2  ////////
    Hold_Menu_2:
    for i = 1 to 100
                lcdout $FE,1, " Waiting 10 sec. "
                lcdout $FE,$C0, "Or click next"
                    if PORTC.3 != 1 then goto Mainloop
    next i
    Goto Mainloop
    Last edited by ScaleRobotics; - 24th November 2010 at 16:17. Reason: added code tags
    I am not completely clear about your setup but the BRANCH command might be what you need/want.
    You could have a VAR that increments every time the button is pressed.
    IF BUTTON = 1 THEN
    CNT = CNT + 1
    Then the BRANCH
    BRANCH CNT,[MENU1,MENU2,MENU3,...]
    Sep 2006
    well this is not exactly whT I am looking for:
    Mainly I have a battery tester which will charge a battery, record the time it took to charge, wait 60 min, discharge the battery, record the time ot took to discharge, and repeat this cycle indefinately. I want the user to be able to SEE the recorded time any time they want to. Here is my Sub routine that does this, although this subroutine gave me a Fatal error- out of memory:
    '///  Display_Charge_Discharge_Time /////
    Display_Charge_Discharge_Time:
    'Show time battery discharge  times, Here is the result of a push on PORTB.3
                lcdout $FE,1, " Aucun test Decharge"
                lcdout $FE,$C0, "No DisC test"
                pause 5000
        Endif
                lcdout $FE,1, " Aucun test Charge"
                lcdout $FE,$C0, "No Charge test"
                pause 5000
        Endif
        if (Battery_Cycle_Charge_Counter = 0) AND (Battery_Cycle_Discharge_Counter = 0) then
                lcdout $FE,1, " Aucun Cycle "
                lcdout $FE,$C0, "en mémoire :("
                pause 5000
        Endif
        if Battery_Cycle_Charge_Counter > 0 then ' Only display if there is something in the array. Show the time for 10 seconds, if PORTB.3 is not press then go back to Mainloop
            Counter = 0
                While BCCC != 0
                    While PORTB.3 != 1        'Hold the time on LCD until 'NEXT' button is pushed again or max 10 seconds
                        Gosub Hold_menu_1 'Pause until PORTB.3 != 1  ..or ten seconds
                    Wend
                        BCCC = BCCC - 1
                Wend
            if Battery_Cycle_DisCharge_Counter > 0 then ' Only display if there is something in the array. Show the time for 10 seconds, if PORTB.3 is not press then go back to Mainloop
            BCCC = Battery_Cycle_DisCharge_Counter
            Counter = 0
                While BCCC != 0
                        lcdout $FE,1, " DisCharge time: " dec Counter
                        lcdout $FE,$C0, dec Voltage_Array_DisCharge_time_RTCDay[Counter]," jour ",dec Voltage_Array_DisCharge_time_RTCHour[Counter],dec Voltage_Array_DisCharge_time_RTCMin[Counter],dec Voltage_Array_DisCharge_time_RTCSec[Counter]
                    Wend
                        BCCC = BCCC - 1
                Wend
            Else
            Endif
        Gosub Hold_menu_2
    Hold_Menu_1:
    for i = 1 to 100
        if PORTB.3 != 1 then
        Endif
    next i
    Goto mainloop
    Here_to_return
    Hold_Menu_2:
    for i = 1 to 100
                    if PORTB.3 != 1 then goto Mainloop
    next i
    Goto Mainloop
    Last edited by ScaleRobotics; - 24th November 2010 at 16:15. Reason: added code tags
    You know . . . they sell these things for automotive batteries, but they do not DEEP CYCLE the battery as your device will. The automotive units charge the battery then discharge for about 10 seconds and check the residual voltage as a measure of the battery's overall fitness.
