My project is starting
Results 1 to 40 of 92
    Aug 2010
    Maryland, USA
    Default I think I found the problem
    I think I have found the problem with interupt. When the interupt hangs and won't leave, it seems BSR=5, when this happens PIR1.1 doesn't get cleared so it just re-enters the int. So the question is, why doesn't PBP make sure the BSR=0 before it tries to PIR1.1=0?
    Or the bigger question is why does it work for Darrel???
    I am posting the program as it is right now, I am using MPLAB, chooseing MPLAB SIM from the debugger menu. then choose the >> not > to animate the program. With this you can see it enter the interupt and leave. I left it running for about 30 min without issue. rem the LAT line and instant hang. sometimes it takes a few times through to get stuck.
    PLEASE, can I get a few people to try this so at least I will know I am not going crazy!!
    ' Name        : Interface card.pbp
    ' Compiler    : PICBASIC PRO Compiler 2.6A
    ' Assembler   : MPASM
    ' Target PIC  : 16F1947
    ' Hardware    : PIMill Interface
    ' Oscillator  : internal
    ' Keywords    :
    ' Description : PICBASIC PRO program to interface parallel port
    ' to 4 stepper drives and limit switches
    ' Configure ports
    ANSELA = %00000000  'port A all digital
    ANSELE = %00000000  'port E all digital
    ANSELF = %00000000  'port F all digital
    ANSELG = %00000000  'port G all digital
    CM1CON0 = %00000000  'No comparaters
    CM1CON1 = %00000000
    CM2CON0 = %00000000
    CM2CON1 = %00000000
    ' preload latches before setting direction
    LATB = %00000000
    LATC = %00000000
    LATD = %00010000 'LED's 0 for red, 1 FOR GREEN should start red
    LATF = %00001111 ' low nibble is drive enable. 1 disables
    LATG = %00000000
    ' I/O direction
    TRISA = %11111111'step and dir inputs
    TRISB = %11000001'7-0 icsp,icsp,h4o,h3o,h2o,h1o,estopO,enable In
    TRISC = %00000000'step and dir outputs
    TRISD = %00000000'led6,i2c,i2c,led5,led4,led3,led2,led1
    TRISE = %11111111'ls4,lsh4.ls3,lsh3,ls2,lsh2,ls1,lsh1
    TRISF = %10010000'manual ready,servo out,dac out,flood input,4en,3en,2en,1en
    TRISG = %11100111'x,x,icsp/mclr,rly2,rly1,Rx2,Tx2,SPINDLE ON
    'REMOVE THIS LINE IF NOT SETTING THE CONFIGS IN CODE SPACE
    @ __config _CONFIG1,_FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    @ __config _CONFIG2,_WRT_OFF & _VCAPEN_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_25 & _LVP_OFF
    'Internal osc setup
    OSCCON = %11110000 'clock is 8 meg. turn on PLL for 32 meg clock
    DEFINE OSC 32
    DEFINE NO_CLRWDT 1
    'Variables
    'Port assignments
    '------------------port B
    ENALL   VAR PORTB.0
    ESTOPO  VAR PORTB.1
    HO1	    VAR PORTB.2
    HO2		VAR PORTB.3
    HO3		VAR PORTB.4
    HO4		VAR PORTB.5
    '------------------port D
    LED0    VAR PORTD.0
    LED1	VAR PORTD.1
    LED2	VAR PORTD.2
    LED3    VAR PORTD.3
    LED4    VAR PORTD.4
    LED5	VAR PORTD.7
    '------------------port F
    EN1		VAR PORTF.0
    EN2     VAR PORTF.1
    EN3     VAR PORTF.2
    EN4     VAR PORTF.3
    DIGIN   VAR PORTF.5
    SERVO   VAR PORTF.6
    MANREADY VAR PORTF.7
    '------------------port G
    SPINON  VAR PORTG.0
    RLY1    VAR PORTG.3
    RLY2    VAR PORTG.4
    '---------------------Bytes
    CNT 	VAR BYTE
    FRAMECT VAR BYTE
    POS     VAR BYTE
    MYFLAGS VAR BYTE
    PRELOAD VAR BYTE
    SPEED   VAR BYTE
    DUMRUN  VAR BYTE
    '---------------------Bits
    COUNTUP VAR MYFLAGS.0
    COUNTDN VAR MYFLAGS.1
    MS      VAR MYFLAGS.2
    LIMIT   VAR MYFLAGS.3
    DRIVEON VAR MYFLAGS.4
    HOMED   VAR MYFLAGS.5
    '---------------------INIT VARIABLE VALUE
    COUNTUP = 1
    COUNTDN = 0
    POS = 127
    FRAMECT = 0
    MS = 0
    HOMED = 0
    CNT = 0
    SPEED = 0
    PRELOAD =  39 'PRELOAD 39 PR = NUMBER OF CYCLES-1
    '5.0 uSec OR 200,000 Hz INTERRUPTS
    'INT HANDLER COMPLIMENTS OF DARREL TAYLOR
    PR2 = PRELOAD
    PIE1.1 = 1        ; Enable Timer2 interrupts
    INTCON.6 = 1      ; enable PEIE
    INTCON.7 = 1      ; enable GIE
    T2CON = %00000100 ; Start Timer2
    DEFINE INTHAND _FiveMicroSec
    GOTO START
    START:
       GOSUB NOTREADY
    Main:      'DO WHATEVER YOU WANT HERE
       IF DRIVEON = 0 THEN
        GOSUB CHECKREADY
       IF (ENALL = 0) AND (DRIVEON = 1) THEN
    	GOSUB NOTREADY
       IF (MANREADY = 0) AND (DRIVEON = 1) THEN
    	GOSUB NOTREADY
       IF (LIMIT = 1) AND (PORTE = $FF) THEN
        GOSUB READY
       IF SPINON THEN
        SPEED=POS
        RLY1 = 1
        SPEED = 0
    	RLY1 = 0
       IF DIGIN THEN
    	RLY2 = 1
    	RLY2 = 0
    READYRETURN:
      IF CNT >= 200 THEN
    	TOGGLE LED5
    	CNT=0
        FRAMECT = FRAMECT + 1
        MS = 1
      IF FRAMECT >=20 THEN
    	FRAMECT = 0
        MS=0
    	HIGH SERVO
      IF PORTE != $FF THEN
       GOSUB SWITCHHIT
      GOSUB SERVOCHECK
    GOTO Main
    SERVOCHECK:
       IF MS =1 THEN
        IF CNT >= SPEED THEN
         LOW SERVO
    	 MS =0
    SWITCHHIT:
       IF HOMED=0 THEN
        GOTO HOMESWITCH
       ESTOPO = 1
       PORTF = PORTF | $0F
       IF (PORTE = 253) OR (PORTE = 254) THEN LED0 = 0
       IF (PORTE = 247) OR (PORTE = 251) THEN LED1 = 0
       IF (PORTE = 223) OR (PORTE = 239) THEN LED2 = 0
       IF (PORTE = 127) OR (PORTE = 191) THEN LED3 = 0
       LIMIT = 1
       DRIVEON = 0
    HOMESWITCH:
       IF PORTE = 253 THEN HO1=1
       IF PORTE = 247 THEN HO2=1
       IF PORTE = 223 THEN HO3=1
       IF PORTE = 127 THEN HO4=1
       IF PORTE = 85 THEN HOMED = 1
    NOTREADY:
       PORTD = PORTD & $F0
       PORTF = PORTF | $0F
       DRIVEON = 0
       HOMED = 0
    CHECKREADY:
       IF ENALL = 0 THEN RETURN
       IF MANREADY = 0 THEN RETURN
       IF LIMIT = 1 THEN RETURN
    READY:
       PORTD = PORTD | $0F
       PORTF = PORTF & $F0
       DRIVEON = 1
       LIMIT = 0
    '---[TMR2 - interrupt handler]--------------------------------------------------
    FiveMicroSec:
        LATF = LATF ^ 32     ;  TOGGLE DAC
        CNT =CNT+1
        PORTC = PORTA
        PIR1.1 = 0          ; clear the interrupt flag
    @ RETFIE
    -Bert
    Aug 2010
    Maryland, USA
    Don't know why I need it, but this works:
    FiveMicroSec:
    '    LATF = LATF ^ 32     ;  TOGGLE DAC
        CNT =CNT+1
        BSR = 0
        PORTC = PORTA
    @ RETFIE
    I mean, I get why setting BSR=0 fixes it, just don't know why I need to.
    -Bert
    Just a shot in the dark....
    CNT  VAR  BYTE  BANK 0
    Aug 2010
    Maryland, USA
    OHH, great idea!! Thanks Dave, I will try this now.
    So sad, got an error : Bad BANK number
    -Bert
    Have you tried any of this in real life? Or just SIM?
    Aug 2010
    Maryland, USA
    its all in real life. I only use the MPLAB SIM when I have a problem I can't reason out, like why does the int hang. for that i need to see registers. But it showed up in real life first by my LED not flashing.
    -Bert
    Further explanation after my reply in the "Bug" thread.
    When there was ...
    LATF = LATF ^ 1
    LATF is is BANK7, and since PBP thought it was in BANK0, it would have changed to BANK7 to access LATF, and at that point it knew it was in BANK7.
    So then it changed back to BANK0 to access CNT, PORTA, PORTC etc.
    When the LATF statement was commented, it thought it was still in BANK0, and didn't try to change the bank, not knowing what bank it was really in at the start of the interrupt.
    Remember that this type of ASM interrupt using PBP statements, goes against the standard rules of interrupts.
    I'm still embarrassed though.
    Why???
    So
    BSR = 0
    at the beginning of the ISR will do what with LATF?
    I thought it had something to do with being in the wrong bank, but like you said CNT was already in BANK 0.
    How should this be done? I am getting more confused than normal.
