My project is starting
Results 1 to 40 of 92
    Of course I have to post this kind of thing here, cuz you guys are the only folks I know that can appreciate these small feats.
    I know what you mean.
    The first time I did a blinky with a PIC it was around the holidays. I called my wife over and excitedly showed her the LED turning on and off. She looks at it for a bit, walks over to the tree, plugs it in, waits for the lights to start blinking, turns to me and says, "SO". She then leaves the room.
    Aug 2010
    Maryland, USA
    more progress, but a little confusion.
    Worked through all the issues of getting everything to work together. Compiled and programmed the blink program that pops up in the MCS program. Mind you I am using MPLAB. Well heres my confusion: with the pauses left at 500, it takes about 5 sec to blink. If I change it to 50, seems about 1/2 sec as the program says it should. Now there are no config,define's, or whatnot, Any thoughts on this?
    -Bert
    What are you using for an oscillator? Type and speed.
    The default configs in the PBP directory *.inc file has the OSC set for HS.
    And PBP defaults to 4MHz.
    If you have an external OSC add
    DEFINE OSC x
    x being speed.
    Aug 2010
    Maryland, USA
    I think I just found the problem. I left too much up for granted. Being new to this chip, I never dreamed it would default to a 500K clock!
    BTW, I am running intosc (apperantly at 500K, not 4M like I assumed) So I will set osccon to be 4M and see what happens
    EDIT: How fantastic life is when you tend to the little things. now works as it should. Off to do more fun stuff
    -Bert
    Aug 2010
    Maryland, USA
    New question
    Heres a snipit:
    ' Configure pins for digital operation (uncomment as needed).
    ' These settings are intended as simple examples.  For more detail,
    ' see the appropriate device datasheet for register descriptions.
    'ANSEL =  %00000000  ' 16F88, 16F688, 16F690, 16F88x
    'ANSELH = %00000000  ' 16F690, 16F88x
    'ADCON1 = %00000111  ' 16F87x, 16F87xA, 18F452
    'ADCON1 = %00001111  ' 18F4620
    Why when I uncomment the ANSELH line, I get a syntax error for that line? How should I be setting it?
    -Bert
    Aug 2010
    Maryland, USA
    Well I don't get it, but after changing nothing, it works. go figure
    -Bert
    Looks like, but I have not used this chip, that the ANSEL has changed some.
    ANSELA
    ANSELE
    ANSELF
    ANSELG
    ANSELA = %00000000
    ANSELE = %00000000
    ANSELF = %00000000
    ANSELG = %00000000
    Maybe...
