MPU-6000 World’s First Integrated 3-axis Gyroscope, 3-axis Accelerometer
Results 1 to 4 of 4
    Default MPU-6000 World’s First Integrated 3-axis Gyroscope, 3-axis Accelerometer
    I thought this was pretty cool. Gyros and accelerometers all in one chip, the first of its kind.
    http://invensense.com/mems/gyro/mpu6000.html
    • Digital-output of 6 or 9-axis sensor fusion data in rotation matrix, quaternion, or Euler Angle format
    • Tri-Axis angular rate sensors (gyros) with a sensitivity of 131 LSBs/°/sec and a full-scale range of ±250, ±500, ±1000, and ±2000°/sec
    • Tri-Axis accelerometers with a programmable full scale range of ±2g, ±4g, ±8g and ±16g
    • Reduced settling effect and sensor drift by eliminating cross-axis sensitivity between accelerometers and gyros
    • Digital Motion Processing™ (DMP™) engine offloads complex sensor fusion, sensor timing synchronization and gesture detection
    • Motion Processing Library support for Android, Linux and Windows
    • Embedded algorithms for run-time bias and compass calibration. No user intervention required
    • Digital-output temperature sensor
    • Digital input on Sync pin to support video Electronic Image Stabilization and GPS
    • Programmable interrupt supports gesture recognition, panning, zooming, scrolling, free fall interrupt, high-G interrupt, zero-motion detection, tap detection, and shake detection
    • VDD supply voltages of 2.5V±5%, 3.0V±5%, 3.3V±5%; VDDIO at 1.8V± 5%
    • Gyro operating current: 5mA, gyro standby current: 5µA; accelerometer operation current: 350µA, accelerometer low power mode current: 20µA@10Hz
    • 400kHz Fast Mode I2C or up to 20MHz SPI serial host interfaces
    • On-chip timing generator with ±1% frequency variation over full temperature range
    • User self test
    • 10,000 g shock tolerant
    • Smallest and thinnest package for portable devices (4x4x0.9mm QFN)
    • RoHS and Green compliant
    http://www.scalerobotics.com
    Aug 2010
    Maryland, USA
    Default But can we buy it yet?
    Walter you HAVE to stop putting these way too cool things up here. I saw this on their site about a year ago, they had it in a block diagram saying it was the way to go, but no information was available for it. I guess they finally got it out.
    -Bert
    Miami, Florida USA
    Sparkfun has a similar product (not a single chip though). It communicates with the MCU with an I2C connection also. It has a 3-axis accelerometer (ADXL345) and a 3-axis gyro (ITG-3200). It is kind of pricy and right now is out of stock.
    http://www.sparkfun.com/products/10121
    Anonymous
    This is what has me really interested:
    The MPU-6000 has an embedded 3-axis gyroscope, 3-axis accelerometer, and Digital Motion Processor™ (DMP™) hardware accelerator engine with a secondary I2C port that interfaces to third party accelerometer, compass, or other sensors to deliver a complete 9-axis sensor fusion output to its primary I2C port as a single data stream for the application.
    Of course, DMP could just be a new marketing term. But it would be interesting to see what kind of processing it can do. 9 axis fusion output sounds pretty nice. I wonder if they are doing any kalman filtering. Guess we will have to wait for it's data sheet.
