USB HID is slower than often using PIC18f2550
Results 1 to 7 of 7
    Oct 2009
    Default USB HID is slower than often using PIC18f2550
    Hi all,
    I was working on USB HID and CDC last weeks with successful applications using 18f2550.
    I made alot of codes and tested them on breadboard.
    yesterday, i made a prototype PCB for my pic 18f2550.
    the problem is that, i find that my labtop takes more time to recognize my HID device.
    when i was using breadboards, my labtop recognize PIC almost instantly. but now it takes about 10 seconds to see it(every time i plugg it , not only the first time). i tried to change the usb capacitor to 470nf insread of 220nf. but nothing changes.
    the program works fine. HID device is ok and communicates will with pc. but i need to know why is it slower to be recognized now? provided that i didnt change any component when i moved from breadboard to PCB.
    Are you powering your circuit from the USB ports +5V?
    If so, it's likely the delay is in your reset circuit on MCLR.
    Quite often people will put a capacitor on MCLR, thinking it will be more stable and not reset.
    But instead it just adds several seconds to the power-up reset time.
    MCLR is usually a Schmitt Trigger input, so the capacitor has to charge to over 4V before it releases the PIC from "RESET".
    If you have a cap there, try removing it.
    Oct 2009
    Yes i m using USB rail to power up my MCU. but i dont use a capacitor on MCLR.
    I only use a 4k7 resistor connected to USB (+5v) supply.
    the strange thing is as i said before, i m using the same circuit i tested on breadboard where it was working fast without any delay on power up.
    i double checked crystal capacitors ( 4MHz with 22p farads) they are as stated in the datasheet.
    i also checked the voltage coming out from USB, it was 5.6v
    the MCLR pin comes to 5.5 volts instantly after attach it to usb as i m using only 4k7 resistor without any capacitor.
    Well, if it is truely the exact same circuit, and exact same program ...
    About the only difference between a breadboard and a PCB is the extra capacitance inherent in the breadboard.
    Do you have at least one 0.1uF capacitor between VDD and VSS close to the PIC?
    And maybe a 10uF cap close to the USB port?
    Is "Low Voltage Programming" disabled in the configs?
    Is IESO disabled?
    Is it the exact same crystal? Parallel or series cut?
    Oct 2009
    thx darrel,
    I already have 100nf ceramic capacitor between vdd and vss so close to PIC.
    LVP disabled, IESO disabled
    i have 100nf close to used connector.
    the crystal is the same. i dont know if it is parallel or series cut. but i know it is connected parallel with two filtering capacitors 22p at each leg. it is connected as in datasheet.
    any idea whats going on?
    i ll try to use 10uf close to usb ( even i think its a huge capacitance as much as USB port is concerned) and i ll see if it will solve the problem
    see u tomorrow, thx darrel
    Do you have a capacitor between VUSB and VSS? What value?
    Can you post the schematic and/or the board layout?
