Thermostat
Results 1 to 16 of 16
Thread: Thermostat
    Smile Thermostat
    Good day
    My father purchased a thermostat hobby kit to switch a element on and off for his little parrots.
    See (http://www.esr.co.uk/manuals/manual_mk138.pdf)
    The relay that's in the circuit cannot handle 220v AC, can I replace it with a relay that can handle 220v AC or can I use the temperature sensor in my own pic project to switch another relay from picbasic?
    Thank you!!
    Th relay footprint is common and you can find all flavors of relays.
    Another solution is to use an external 24V relay and then drive your 220 volt load.
    Ioannis, thank you very much for your reply.
    So do I understand correctly that one option is to replace the relay with another one that's for example 12v / 220v?
    You are correct.
    Have a look at digikey, farnell or you favorite provider.
    Thank you very much, I really appreciate it!!!
    malc-c's Avatar
    malc-c Guest
    Or you could use an opto-isolator and Triac to switch the mains voltage. The advantage of a relay is that it's fairly safe, but the noise from being energized could send you an your parrot bonkers !
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by koossa View Post
    You could use a DS18B20 or LM35 digital sensor and a PIC and easily make your own - I've just completed a 4ch pulse proportional thermostat and light controller for my snakes based on an 18F4580 and 4 x DS18B20 sensors
    Thank you Malcolm.
    Would it also work if I "reinforce" the 220v part of the tracks with thick copper cable?
    malc-c's Avatar
    malc-c Guest
    To be honest - mount the relay off the board - then take two wires from the coil to the PCB, then wire your mains wiring to the relay.
    Malcom, have you done any Audio Amplifiers or Pre-amps inthe past?
    malc-c's Avatar
    malc-c Guest
    No, why ???
