Degrees to decimal conversion
Results 1 to 4 of 4
    Hi Darrel,
    Thanks a lot this is working perfect
    Imagine if I would like to do the opposite
    so from a 10 or 12bit value (representing 1 revolution) to deg.xx
    Can you put me on the right tracks to do that ?
    Decimal_value_10bit var word '(0-1024)
    Decimal_value_12bit var word '(0-4098)
    degrees var word '(0-360)
    degrees_fraction var byte '(.xx)
    degree_Total var word
    Quote Originally Posted by RFsolution View Post
    It's essentially the same thing, with the order of the formula reversed.
    Originally for degrees to 16-bit we had ...
    65536 * degrees / 36000 (notice I've changed the constants)
    The reverse would be ...
    16-bit * 36000 / 65536
    You can change between any of the scales by simply changing the order and the constants.
    degrees to 12-bit ... degrees * 4096 / 36000
    12-bit to degrees ... 12-bit * 36000 / 4096
    degrees to 10-bit ... degrees * 1024/ 36000
    10-bit to degrees ... 10-bit * 36000 / 1024
    Here's a macro for N-Bit_Math that will let you do it easily ...
    Convert  macro WFrom, Frange, WTo, Trange
        MOVE?WP   WFrom,  _Temp1              ; copy From value to Temp1 Pvar
        MOVE?CP   Frange, _Range1             ; put From Range in Range1 Pvar
        MOVE?CP   Trange, _Range2             ; put To range in Range2
        MATH_MUL  _Temp1, _Range2, _Temp1     ; Temp1 = From * To_Range
        MATH_DIV  _Temp1, _Range1, _Temp1     ; Temp1 = Temp1 / From_Range
        MOVE?PW   _Temp1, WTo                 ; copy result to word variable WTo
    Then you can convert any of the scales to any other scale by providing the macro the From value with the "range" that variable goes to, a variable to put the result in and the range that variable should span.
    To convert the original degrees to 16-bit, you would ...
    @   Convert _degree_Total, 36000, _Decimal_value_16bit, 65536
    or to 12-bit ...
    @   Convert _degree_Total, 36000, _Decimal_value_12bit, 4096
    Going the other way is just as easy.
    @   Convert _Decimal_value_16bit, 65536, _degree_Total, 36000
    @   Convert _Decimal_value_12bit,  4096, _degree_Total, 36000
    Here's a test program ...
    <font color="#000000">rxd                 <b>VAR </b>PORTC.7
    txd                 <b>VAR </b>PORTC.6
    <b>HIGH </b>txd
    Decimal_value_16bit <b>VAR WORD </b><font color="#000080"><i>'(0-65535)
    </i></font>Decimal_value_12bit <b>VAR WORD </b><font color="#000080"><i>'(0-4095)
    </i></font>degrees             <b>VAR WORD </b><font color="#000080"><i>'(0-359)
    </i></font>degrees_fraction    <b>VAR BYTE </b><font color="#000080"><i>'(.xx)
    </i></font>degree_Total        <b>VAR WORD
    </b><font color="#000080"><i>'----[N-Bit Math]---------------------------------------------------------------
    </i></font>PRECISION  <b>CON </b>4 SYSTEM          <font color="#000080"><i>; 4 bytes=32-bit
    </i></font><b>INCLUDE </b><font color="#FF0000">&quot;N-Bit_MATH.pbp&quot;
    </font>Temp1    <b>VAR BYTE</b>[PRECISION]
    Range1   <b>VAR BYTE</b>[PRECISION]
    Range2   <b>VAR BYTE</b>[PRECISION]
    <b>ASM
    </b><font color="#008000">Convert  macro WFrom, Frange, WTo, Trange
        MOVE?WP   WFrom,  _Temp1              </font><font color="#000080"><i>; copy From value to Temp1 Pvar
        </i></font><font color="#008000">MOVE?CP   Frange, _Range1             </font><font color="#000080"><i>; put From Range in Range1 Pvar
        </i></font><font color="#008000">MOVE?CP   Trange, _Range2             </font><font color="#000080"><i>; put To range in Range2
        </i></font><font color="#008000">MATH_MUL  _Temp1, _Range2, _Temp1     </font><font color="#000080"><i>; Temp1 = From * To_Range
        </i></font><font color="#008000">MATH_DIV  _Temp1, _Range1, _Temp1     </font><font color="#000080"><i>; Temp1 = Temp1 / From_Range
        </i></font><font color="#008000">MOVE?PW   _Temp1, WTo                 </font><font color="#000080"><i>; copy result to word variable WTo
      </i></font><font color="#008000">endm
    </font><b>ENDASM
    </b><font color="#000080"><i>'----[Main Program Loop]--------------------------------------------------------
    </i></font>Main:
        <b>SEROUT2 </b>txd,84,[13,10,<font color="#FF0000">&quot;Enter Degrees (Max=359.99): &quot;</font>]
        <b>SERIN2 </b>rxd,84,[<b>DEC </b>degrees,<b>DEC2 </b>degrees_fraction]
        Degree_Total = degrees * 100 + degrees_fraction
        <font color="#000080"><i>;--- degrees to 16-bit ---
    </i></font><font color="#008000">@   Convert _degree_Total, 36000, _Decimal_value_16bit, 65536
        </font><b>SEROUT2 </b>txd,84,[13,10,<font color="#FF0000">&quot;16-bit: &quot;</font>,<b>HEX4 </b>Decimal_value_16bit,<font color="#FF0000">&quot;  &quot;</font>,<b>DEC </b>Decimal_value_16bit,13,10]
        <font color="#000080"><i>;--- degrees to 12-bit ---
    </i></font><font color="#008000">@   Convert _degree_Total, 36000, _Decimal_value_12bit, 4096
        </font><b>SEROUT2 </b>txd,84,[<font color="#FF0000">&quot;12-bit: &quot;</font>,<b>HEX4 </b>Decimal_value_12bit,<font color="#FF0000">&quot;  &quot;</font>,<b>DEC </b>Decimal_value_12bit,13,10]
        <font color="#000080"><i>;--- 16-bit to degrees ---
    </i></font><font color="#008000">@   Convert _Decimal_value_16bit, 65536, _degree_Total, 36000
        </font><b>SEROUT2 </b>txd,84,[<font color="#FF0000">&quot;Deg from 16-bit: &quot;</font>,<b>DEC </b>degree_Total/100,<font color="#FF0000">&quot;.&quot;</font>,<b>DEC2 </b>degree_Total,13,10]
        <font color="#000080"><i>;--- 12-bit to degrees ---
    </i></font><font color="#008000">@   Convert _Decimal_value_12bit, 4096, _degree_Total, 36000
        </font><b>SEROUT2 </b>txd,84,[<font color="#FF0000">&quot;Deg from 12-bit: &quot;</font>,<b>DEC </b>degree_Total/100,<font color="#FF0000">&quot;.&quot;</font>,<b>DEC2 </b>degree_Total,13,10]
    <b>GOTO </b>Main
    And here's some output from the test program ...
