Thanks for the help you guys. I'll look through the code and try to decipher what exactly its doing and make sure I have it set up for my application.
Is the serout2 command just sending the data to the lcd? Rather than using an LCDOUT command?
Got to the lab early this morning, got my LCD up and running. Went to reconfigure my op amp and find out its grounding something across the +-15V pins.No idea what is going on because last time I used the circuit it was working perfectly. Oh well, good thing I've got another 4 op amps on the way!
